Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Garbage disposal wont work
First i had a draining problem knocked out the plug for the dishwasher while it was installed and now the disposal will not work!!!! Help!!!
  • Anonymous Feb 25, 2009
    What happens if the plug goes into the disposal and you can't get it out? Will it eventually be ground up and gone?
  • 137 Answers
I'm going to ask a dumb question first. You didn't by any chance leave the plug in the disposer did you? I didn't think so but I had to ask.
Next I would check the "red" reset button on the side ot bottom of the disposer, reset it by pushing hard it should "click".
If this doesn't work look under the disposer and see if the is a allen wrench opening in the middle of the disposer, if there is get the proper size wrench (sometimes they are included with the disposer) insert it an turn the disposer counter clock wise, if this turns freely, the next step wold be to call the man.
Posted on Feb 15, 2009
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 | Dishwashers
Water wont drain
Check sink drain and drain hose for restriction
Check the drain valve
Check the drive belt
Test the timer motor
If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Before attempting any testing or repairs unplug the dishwasher or shut off the power.
Jun 18, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
After I installed my Badger 5 my dishwasher would not drain. Is there a plug in the dishwasher port on the side of the disposal and how do I remove it?
There is often a plug in the ISE as many people use them without have a dishwasher connected to them. Quite often it is just a thin plastic membrane that can be knocked out with a screwdriver. There should also be a note to this effect in your installation instructions for the ISE.
Sep 14, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My gld6500l dishwasher worked fine, then my husband replaced a broken garbage disposal. The next day I ran my dishwasher and it now will not drain. Coincidence, or could the two be related?
Yes probably a connection. The dishwasher drain connects to the the Garbage disposal . If the line is kinked then the dishwasher will not drain. Plus the dishwasher has to have a plug knocked out where the drain line goes into the garbage disposal. I am sure this is your problem.
Jun 02, 2010 | GE 24 in. GLD6500L Built-in Dishwasher
My dishwasher won't drain after I installed a new garbage disposal.
Check the drain spout of the disposer where you connected the drain hose from the dishwasher and make sure you`ve knocked out the plug in the spout.
If not, with the aid of a long screw driver and a hammer, or a firm smack with the palm of your hand you should be able to knock out the plug. Then reach in the disposer and remove the plug you`ve just knocked out, reconnect the drain hose for your dishwasher and you should be good to go.
Hope that help`s. good luck.
macmarkus :)
Mar 06, 2010 | KitchenAid Dishwashers
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher won't drain
remve the drain line connected to the garbage disposal take a flat blade screwdriver insert it into the garbage disposal and hit the end of the screwdriver , the plug will pop out
to verify after hitting it stick the screwdriver back in if it has not removed the plug do it again
Apr 04, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
383 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
