Question about Pioneer A109 2-Channel Amplifier
Powerspec lcd tv v30cmbt
I have a 30 inch powerspec lcd tv when i went to turn it off i got shocked from static gling and now it keeps blinking avc on avc off
  • Scott Frye
    Scott Frye May 11, 2010
    Hi...
    It could be that you had enough "potent-personal-lightning" that some circuits sustained static damage. Is the TV new enough to get warranty coverage?
My 30" PowerSpec LCD TV won't turn on. I've tried the factory reset and unplugging it, but nothing worked. All I see is a little yellow light on the lower right-hand corner of the frame. Is there anything...
I had the same problem it's the power it switches on is off and off is on I had to plug and unplug it from the back and shock the television until it remained off than you can turn the tv on and you'll get a picture.
May 29, 2010 | Televison & Video
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
I have an Insignia 32'' lcd tv. I shut it off by
when you got off the couch to turn of your set you gave it a static charge which corrupted the CPU try unpluging unit for 30 seconds see it that fixes your problem if not you will need a main board
Nov 18, 2009 | Insignia IS-LCDTV32 32 in. Television
Static shock when we turn tv off and it went blank
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 15, 2009 | Akai LCT3285TA 32 in. LCD Television
Insignia 27 LCD tv that got a small static shock, now no picture.
try unplugging the tv for an extended period of time.(30-60min) plug it back in, that should do it, if not it may need a new power supply,
Dec 26, 2008 | Televison & Video
Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know psxpirate25@hotmail.com
Jul 05, 2008 | Televison & Video
Out of sync message
When you first turn on the unit very quickly push the imput button to switch sources.It is stuck on the computer imput.
Feb 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Pioneer A109 2-Channel Amplifier Logo
405 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
