Question about Magic Chef 9122 Gas Single Oven
Buzzing noise at the self cleaning dial for a wall oven.
I had some work done on my house while I was away and the Electrician turned off the power to the house. After turning it back on the self cleaner dials for setting the time are making noise and he disconneded the wires to make it stop. Has anyone ever experienced this? I have an old Magic Chef Wall Oven model # 996-4CX that works absolutely fine and so did the self cleaner until the powered off. It is just at the knobs for the self cleaner. It is a buzzing like the timer is done. Can anyone give me any suggestions?
Also, the analog clock hasn't worked in forever. Does anyone know if it is worth repairing?
Thanks, Cathy
  • 306 Answers
SOURCE: Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Posted on Nov 26, 2008
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Posted on Dec 18, 2008
  • 8197 Answers
SOURCE: magic chef manual
You can download it here but you need the right model #.
As for the temp adjust it is best if you get an repair man out to do that.
Good Luck
SOURCE: My mom has a Magic Chef oven, model 5892VRV. It
The f1 problem is a losing battle. If the oven is otherwise working fine, save your money and just disconnect (ie, with wire snips) the buzzer alarm inside the controller. You'll still be seeing f1 most of the time when you are not using the oven, but so what? I performed this "fix" several years ago and haven't regretted it.
Posted on Oct 17, 2009
SOURCE: My Magic Chef oven (36"
Hi, most likely that Power outage has damaged the main controller board, it is not so much the outage as the reconnection of the power after an outage, you see when this occurs, when the power is restored usually everything is still ON, then when reconnected, the "Inrush" current can be enormous, and it damages the sensitive electronics, frequently.
Most likely the controller and or the thermostat has failed, another candidate is the thermistor temperature sensor.
To effect a repair one MUST obtain a service manual, this has all the circuits and troubleshooting steps and parts numbers too, it is a must have. They can be obtained from the manufactures website below.
Whenever there is an outage one must race around and turn off, and withdraw every power point and appliance to stop this from occurring. reconnect and turn them back on when all is well again.
This may indeed be a job for a professional, in this case please contact magic Chef, and ask for a referral to an authorised repairer, when they call ask for a 'Quote" for the repair, before allowing any repair work to be done.
below is a DIY self hep site.
Posted on Nov 30, 2010
I have a wall oven that is 15 years old and it's making a loud noise, after it's turned off. This has never happened before.
Don't burn your house down! Get a new wall oven. FYI Sears no longer sells Whirlpool.
Nov 10, 2017 | Whirlpool Ovens
Hi I have a sagi wall oven and I carnt stop the beeping any help will be great
pull or turn off the ovens main fuse at the house power board
if beeping continues after power is restored to the oven
turn off the ovens power again
get the oven checked out by an electrician
Apr 09, 2017 | Ovens
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
Frigidaire Gallery oven won't work after we used the self clean feature. All the controls seem to work & we are not getting an error message, however, when it says that the door is locked it is...
Hello Gillian, thank you for your post!
Let's try reprogramming your wall oven by either unplugging it or flipping the circuit breaker off. It is necessary to wait roughly ten minutes and then turn your wall oven on. Select an option and confirmed that the door is securely latch. If the issue persists, then the temperature may have tripped the internal sensor of your wall oven and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Also, your wall oven may possibly have a communication problem with the EOC (Electronic Oven Control). Personally, I would recommend contacting a professional for a further evaluation.
Best regards, Chris!
Dec 25, 2013 | Frigidaire 30 in. Electric Gallery Series...
No I see double wall oven
I have a B50STIP/1 wall oven who oven selection dial has worn away.
Can someone please tell me what is on the dial at 5.00 oclock?
Thank you ,
Jul 13, 2013 | Ovens
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
I used the self cleaning feature and halfway through got f2 (too hot). we turned off the power and let the oven cool down. now it is making a buzzing noise when the door is closed and the oven is off and...
Sensor inside oven towards the back two screws remove and unplug sensor replace with new one. Sensor burns out when using the self clean feature. New sensor $15-$20
Jan 24, 2010 | GE Profile JTP56 Electric Double Oven
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Magic Chef 9122 Gas Single Oven Logo
262 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
