Question about HP PSC 2175 All-In-One InkJet Printer
Hp psc 2179 all-in-one printer
The printer is clicking and won't print. It says it's scanner failure, and to turn the power off, then on again. I have done this firstly from the machine, then when that didn't work, from the mains plug. Please advise.Thank you.
  • 2 more comments
  • patriciawate Feb 18, 2009
    I finally got on to hp.com who rectified the problem. There was no appropiate answer on your page, unless I was willing to pay for it.
  • Anja van Vugt Feb 23, 2009
    the scanner clicked and don't make copies.
    The scanner stay hang and makes a noise. (click click)You can not makes copies. The printer say: scanner failed, stop it and try again. Sometimes can i make copies, but the most times not.
  • BG101 Mar 11, 2009
    I need to know how to remove the top section. My scanner has exactly the same problem (2179), clicking and then reporting "scanner failure". Probably something as simple as a bad contact on a microswitch or dirt on a sensor (so the scanner can't find its "home" position). One screw is accessible but the other is hidden under the control panel and there is no (obvious) way of removing this without using a hammer. Or do I have to drill a hole through the top cover?
    BG
Using the instructions found here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00553775&dlc=en&product=90809
I opened the scanner and found that the cold-cathode lamp is failing. Moving the optical assembly away from its home position (to the middle of the scanner) allows the unit to initialize so at least the printer works.
I'll investigate availability of replacement lamps.
BG
Posted on Mar 13, 2009
    Genius:
  • 2,120 Answers
Uneconomical to replace the SCANNER
Posted on Feb 15, 2009
Printer won't print; says scanner only after
Follow these steps to resolve your problem..
Solution #1 Power cycle both devices (Printer & Computer)
  1. Turn off your printer.
  2. Unplug the power chord at the back of your printer.
  3. Completely shutdown your computer.
  4. Unplug / disconnect the USB cable at both ends (printer & computer)
  5. Wait for at least 1min.
  6. Plug the power cable back in to the printer make sure that the other end of the power cable is connected directly to the wall outlet.
  7. Turn on the printer.
  8. Check if you can make a copy, if yes proceed to the next step.
If not, and you are still hearing some unusual sounds on the printer go to the last step.
Solution # 2 Check if you can now print using your computer
  1. Plug the USB cable back in to the both ends (printer & computer)
  2. Download the Print diagnostic utility (click on Download below to download the tool)
  3. It will ask you to run or save it. (save it, so that you can use it on the next time that your having problem with printing issues)
  4. Run the software.
  5. Highlight your printer by clicking on it.
  6. Click on Diagnose.
  7. If you have to the FIX button available, click on it.
  8. After fixing the issues, restart button will appear. click on it.
  9. Check if you can now print.
DOWNLOAD (print diagnostic utility)
Solution #3 Call HP and have your printer trade in (last step) Call HP @ 1-800-474-6836, If the printer is no longer covered by the warranty charges may apply.
Feb 19, 2011 | HP PSC 2210xi All-In-One InkJet Printer
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
My hp psc 750 will print from my computer, but I cannot make a copy. It keeps saying, "Scanner Failure. Turn off and on again." I have done this several times and it still will not make a copy.
My hp psc 750 will print from my computer, but I cannot make a copy. It keeps saying, "Scanne Failure. Turn off and on again." I have done this several times and it still will not make a copy.
Apr 20, 2009 | HP PSC 750 All-In-One InkJet Printer
It automatically print a page everytime I start my hp psc 1315
Hi Siddarth
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner failure during the initalization/starts up.
Sound as if your scanner is broken..
Could be something in there stopping it from moving, the motor could be bad.
It might have Home Positioning errors, causing this error.
To get it Fixed? The machine is about 140 dollars on Amazon?
The company I work for, the first hour is 125 (I do not know how much it cost to repair these)
Unfortunately these little ink jet printers are not designed to be repaired. They are considered throw away.
Sorry
Oct 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Scanner Failure
The only thing I can surgest is that you check installed programs I found that the 750 is very fussy about being the only kid on the block. Maybe worth trying a commercial program that says it will remove "junk" from your hard drive
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Scanner Falure Issue
Clean Scaner Unit Properly its not easy to done
other wise all engineer
May 26, 2008 | HP LaserJet 2840 All-In-One Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Copy on my 2179 hp all-in-one
Hi Simoandson, The scanner failure message usually occures when the scanner bulb is not getting heated properly or the scanner bulb is defective. We can check with the issue by connecting the printer direcly to wall outlet and then lift the scanner lid and press scan or copy button and check for the scanner bulb is lit and scanner machinisum is moving fine under the scanner bed.. There is also a Firmware update released by HP that can be downloaded and installed to fix the issue: Here is the link: ========= http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en ======= Just click on the link and in the download webpage click on the download only button and select save to save the download to the computer and once the file is saved make sure that the printer is turn on and connected fine and click on the file to install the firmware update to the unit If the issue still presists try to performe the steps in the below webpage: =========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=1138346&dlc=en&lang=en ======== Hope this will help you to fix the issue Regards, Barret.
Sep 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
941 people viewed this question
Seeker5211
Seeker5211
