Question about Star G14-Y Popcorn Maker
Need new kettle for a Galaxy G14 popcorn machine?
The cabinet is a great shape...THe kettle was not taken care of very well. Extreme oil build up...Tried to clean...still looks bad!
    Novelist:
  • 125 Answers
Hello. If you want a new kettle you can contact here:
http://www.star-mfg.com/Scripts/ContactTechServ.aspx
If it just needs cleaning, there are a few products that will dissolve the build up, remember, don't submerge the kettle in liquids. It will have to be done slowly, and take a little time, oh yeah, and effort :)
If you contact the manufacture, they can recommend a cleaner to use.
Hope that helps, and thank you.
Posted on Feb 23, 2009
The Kettle Agitator gets stuck. Appears the Rotating Center is Wobbly. . .
The motor output shaft bushing might have came loose I have seen where it falls out of the motor and the shaft becomes real wobbly and it will cause excessive wear in the kettle cross bar bushing too. also make sure the cross bar and lid assy. is not come loose from the kettle.
Feb 27, 2016 | Star Manufacturing Star G12-Y - Galaxy...
My popcorn maker won't spin the kernels. I think it's the stir rod?
There are many possible problems that will cause your agitator to not spin, But you said the gear in the cabinet comes off easily, it should not.
There is a flat part of the motor shaft that extends thru the top of the cabinet that the gear should be tightened onto with an allen wrench via a set screw. This is the first place to check. When the motor is on, you should not be able to stop that cabinet gear from turning. (not easily anyway).
Oct 25, 2014 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Popcorn maker worked great for a matinee then for the evening show the kettle no longer heated up
Your kettle has had a ground fault, and damaged the switch in the process. Do not Continue to Try and use.
Take the kettle to a gold medal dealer, and replace the switch in the cabinet.
Jul 20, 2014 | Gold Medal 2003 Whiz Bang Popcorn Maker
I have an old popcorn maker. The kettle is very rusty. I'm using a carbon cleaner for all of the thick build up of oil, but how do I remove the rust?
Older Kettles that are rusty, will always be rusty. Use the carbon cleaner, and steel wool to remove the rust. But you must season the steel immediately after to stop new rust from forming.
To season the kettle, heat it up to operating temp, with a light coating of oil on it. You want to burn the oil, (creating Carbon) to stop new rust from happening. That is the only way to avoid new rust.
May 07, 2014 | Kitchen Appliances - Others
Our elementary school has this Gold Medal 2213 Antique *** 90 Popcorn Machine. We don't seem to have any manual for it now. We would like to use regular corn oil and kernels, versus the all-in-one bag...
Generally, you want 3 oz. of corn to one 1oz of oil. The amount of corn you can put in the kettle depends on the size of the kettle. So take the kettle size, (I think that machine is an 8 oz popper) and divide 8 by three to get 2.66 oz. (about a third of a cup) of oil needed. So you would use 1 cup of corn, and a third cup of oil.
Feb 23, 2011 | Gold Medal 2213 Antique Gay 90's Mega Pop...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
I need a new kettle where do I go get one?
you can order a new kettle online at www.ebay.com u have great offers there.
Jun 09, 2009 | Bond Helman Old-Fashioned Movie Time...
Throws the breaker,,i installed a new cord and plug
Check to make sure that you have it wired correctly almost sounds like you have the positive and the negative on the machine crossed with what your house is
May 28, 2009 | Galaxy G14-AT Popcorn Maker
Corn not properly popped.wastage is more than optimum level.
Are you using fresh popcorn? Old seed will dry out and do this. Is your machine maintaining the proper temperature?
Feb 26, 2009 | Galaxy G14-AT Popcorn Maker
Popcorn maker
When Popper Has Popped Corn Just Before.
1. Pour the properly measure amount of Oil into the kettle.
2. Wait about 45 seconds - or until the Oil in the kettle starts to smoke slightly.
3. Pour the contents of the properly measured corn cup (kernels plus popcorn salt or Flavacol) into the kettle.
4. Wait about 2 1/2 minutes. If you are using a pan on the stove without an agitator, you must constantly shake gently. When the crackling noise of the popping corn is no longer heard, dump the kettle and empty it completely.
5. Repeat if needed for more popcorn.
6. When you are finished popping, turn off the kettle agitator switch (if you have one) and turn off the Pilot light/ heat switch.
7. After the machine has cooled enough so as not to be dangerously hot, wipe the outside of the kettle with a soft damp cloth. This helps prevent a heavy build-up of the Oil.
TIPS
- Bagged floss keeps a day or two, depending on the humidity
- Use bags to make and display cotton candy in advance - use cones for immediate sales
- Unless you're experienced, it's best to turn off the motor to refill the spinner head
- If machine will be used more than 20ft. from power source, be sure to have an adequate extension cord
Nov 18, 2007 | West Bend 01568 Popcorn Maker
Star G14-Y Popcorn Maker Logo
170 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
