Question about Calvin Klein The Field Controls Company CK-41F 24V Furnaces, Boilers, Unit Heaters & Wat
I have a ravenheat boiler that i have no idea how to reignite
The pilotlight
  • 4 Answers
Cange the thermocoupler. you con get one at any Lowes or Home Depot
Posted on Apr 05, 2009
Inside my ravenheat 120 low nox boiler is a tyre valve which releases pressure do you know where it is possitioned
I would imagine under the front bottom
cover.But if not ,when you take cover off there
should be a diagram.It will be on boiler or the lid
you have taken off.
LUCK
Sep 25, 2014 | Water Heaters
The hot water temperature is not constant with the burner shutting off
You can get a sound like that when there is too much sediment in the bottom of the tank. Turn it off drain and flush it until the water runs clean.
Aug 21, 2014 | Water Heaters
Bosch propane boiler
Some times you have to bleed the line
Dec 27, 2013 | Water Heaters
Ravenheat 80/20 boiler. the boiler looses water pressure but only when working in central heating mode. Boiler holds pressure indefinitely if central heating is not used,hot water can be drawn without a...
Hi, your boilers pressure should be holding 1.5 bar with the relief set about 3. If the pressure is below this the flow switch will cause the boiler to stop as theirs not enough pressure to operate. Another thing, does your boiler have an auto fill system or do you need to plug a hose in to fill it? If its an auto fill system and you lose pressure you could have a leak.
Sep 15, 2013 | Water Heaters
Got a ravenheat ls 1oot combi boiler not working red light on timer on not making any noise works every now and then for short periods
I have a ravenheat 820/20(t) boiler and the pilot will not say alight, I have 20mV from the thermocouple(through the safety switch) and its had a new gas valve fitted(good earth continuity).The heating system is holding pressure at 1.2 bar.
Has anyone got any ideas what could be holding the pilot 'OFF'.
I CANNOT SEE ANYTHING ELSE IN THE PILOT CIRCUIT.
PLEASE HELP !
Dec 20, 2009 | Water Heaters
How do you light a ravenheat pilot light
push in the yellow or grey button on the gas valve and click the piezo ignighter repeatedly keep the gasvalve button depressed for 20 seconds and the boiler should light if it does not you have a fault come back for more advice if this happens
Sep 30, 2009 | Calvin Klein The Field Controls Company...
Non i;n working boiler
Did you put automatic vent plugs on this boiler?This help stop from having air locks.I would try bleeding the high pipe to see if any air come out.The other thing I would check is the valve that out for the pump to pump water around.
Mar 17, 2009 | Water Heaters
I have a ravenheat boiler that i have no idea hoe to reignite
you need to reset it but if it dont light you prob have rectifaction fault
Feb 15, 2009 | Calvin Klein The Field Controls Company...
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Calvin Klein The Field Controls Company CK-41F 24V Furnaces, Boilers, Unit Heaters & Wat Logo
449 people viewed this question
Top Calvin Klein Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Calvin Klein Water Heater Expert? Answer questions, earn points and help others
