Question about Calvin Klein The Field Controls Company CK-41F 24V Furnaces, Boilers, Unit Heaters & Wat
I have a ravenheat boiler that i have no idea hoe to reignite
I have 3 buttons on the front of my boiler but i dont seem 2 be able to get the pilot light to reignite
  • Lou Barta May 11, 2010
    I need more info.....
    Does this boiler have a standing pilot or electronic ignition?
    Problem Solver:
  • 13 Answers
You need to reset it but if it dont light you prob have rectifaction fault
Posted on Sep 12, 2009
More info needed alan 0776 7494009
Posted on Aug 03, 2009
Inside my ravenheat 120 low nox boiler is a tyre valve which releases pressure do you know where it is possitioned
I would imagine under the front bottom
cover.But if not ,when you take cover off there
should be a diagram.It will be on boiler or the lid
you have taken off.
LUCK
Sep 25, 2014 | Water Heaters
Ravenheat 80/20 boiler. the boiler looses water pressure but only when working in central heating mode. Boiler holds pressure indefinitely if central heating is not used,hot water can be drawn without a...
Hi, your boilers pressure should be holding 1.5 bar with the relief set about 3. If the pressure is below this the flow switch will cause the boiler to stop as theirs not enough pressure to operate. Another thing, does your boiler have an auto fill system or do you need to plug a hose in to fill it? If its an auto fill system and you lose pressure you could have a leak.
Sep 15, 2013 | Water Heaters
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
Got a ravenheat ls 1oot combi boiler not working red light on timer on not making any noise works every now and then for short periods
I have a ravenheat 820/20(t) boiler and the pilot will not say alight, I have 20mV from the thermocouple(through the safety switch) and its had a new gas valve fitted(good earth continuity).The heating system is holding pressure at 1.2 bar.
Has anyone got any ideas what could be holding the pilot 'OFF'.
I CANNOT SEE ANYTHING ELSE IN THE PILOT CIRCUIT.
PLEASE HELP !
Dec 20, 2009 | Water Heaters
How do you light a ravenheat pilot light
push in the yellow or grey button on the gas valve and click the piezo ignighter repeatedly keep the gasvalve button depressed for 20 seconds and the boiler should light if it does not you have a fault come back for more advice if this happens
Sep 30, 2009 | Calvin Klein The Field Controls Company...
My Ravenheat LS80 won't give me hot water!
years after the problem..... i find this link. relevant for future people i suppose and definately better than the previous answer which is not applicable at allravenheat.co.uk/pdf/manuals/LS80printV3.1.pdf
Apr 11, 2009 | Water Heaters
I have a ravenheat boiler that i have no idea how to reignite
cange the thermocoupler. you con get one at any Lowes or Home Depot
Feb 15, 2009 | Calvin Klein The Field Controls Company...
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
Calvin Klein The Field Controls Company CK-41F 24V Furnaces, Boilers, Unit Heaters & Wat Logo
1,015 people viewed this question
Top Calvin Klein Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Calvin Klein Water Heater Expert? Answer questions, earn points and help others
