Question about Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor
I have a 715V with the same problem
One of my two 715v's has the same problem. Slowly started losing resolution(s) and now has dropped out all together. It used to "reset" by going down to 640x480 and working our way back to 1280x1024. After a while you could get to 1024x768, now nothing...Bulb is good...Other 715V I am using right now...
    Champion:
  • 220 Answers
This is a problem with the interface or digital signal processing board.You need to replace this board which plugs into the Signal input.
Samir
Posted on Feb 16, 2009
My daughter was on youtube and now the screen size is way too big. how do i get the screen back to normal. i don't know how to adjust the resolution.
If it is a resolution issue you should go to START --> Settings or Control Pannel --> Display
If you look through the tabs in this window you will find where to adjust the resolution of the screen.
If this does not adequately fix the issue you can try holding the CTRL button on the keyboard and slowly scroll the mouse wheel in and out to adjust the zoom inside the Internet Explorer window.
Jun 18, 2011 | Computers & Internet
Gas tank reads empty after filling and driving for a second. Gauge slowly starts to climb back after driving for 5 plus minutes then drops again.
the flue sense in your tank is bad most likely but it could also be just a bad connection between it and your flue gauge witch can be caused by corrosion or a lose wire
Jan 20, 2011 | 2006 GMC Envoy
I have a hp1280 deskjet printer it is print so much slowly
At its fastest, the Deskjet 1280 only prints at 14 pages per minute, and this number decreases if you print in color, use a higher resolution, or use larger than 8.5" x 11" paper.
To increase print speed, try dropping the print resolution from 600x600 (Best) to 300x600 (Fast), and if you are printing something that doesn't have any color, make sure you select black and white in the print properties, rather than color.
Jun 03, 2010 | HP DeskJet 1280 InkJet Printer
1994 BMW Series 5, battery loses charge slowly
if you have a volt meter, check the voltage at the battery before you start the engine and after the engine is running, before could be 11.5v after should be 13.5 or higher but no higher than 14.5, this will test the altenator, check the belt by pressing on the middle of the belt between the two pulleys the belt deflection should not be more than 1/2", if it is tighten and retest altenator
Mar 21, 2009 | 1994 BMW 5 Series
Samsung SyncMaster 710N 17 in. Flat Panel LCD Monitor Logo
603 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
