Question about Maytag Atlantis MAV6000 Top Load Washer
Mav7600aww no hot water
Washer will work in all cycle modes,but no hot water
  • 10,865 Answers
It sounds like the hot water supply is interrupted. This can be due to at least three potential items which are easily checked.
First, make sure the hot water supply is turned on at the nearest faucet. Second, make sure that any in line filter in the hose supplying the hot water isnt clogged. Finally make sure that the hose itself isnt clogged as hot water can carry alot of chemicals in solution but as the water cools the chemicals come out of solution as solids which will gum things up.
please rate my answer as a fixya! thanks.
Posted on Feb 18, 2009
Mav7600aww maytag spinning but not agitating
RDU Appliance Repair 919 827 1482 Serving Raleigh Cary Durham NC
mav7600aww has a brake that goes bad. some will just spin slowly during agitate cycle and not really agitate
Sep 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag lsg7804aae stackable unit. The problem I am having is that the washer will not agitate or fill with water, however the unit will work on the spin cycle in all modes. Opened front panel of...
timer is good, if you tried it on all the different cycles, must be the water inlet valve, does the hot water work, if you set to warm or hot..if so the cold water valve is shot
Dec 19, 2010 | Maytag LSE7806A Top Load Stacked...
My Maytag Atlantis Mod.# MAV7600AWW doesn't come on with the cold water selected. It will come on with warm or hot water. The spin cycle seems to work ok when dialed to it. Before the washer seemed to...
the machine control opens both hot and cold water valves and then the machine sensor monitors this through a water temp sensor in the fill line till a certain amount of resistance is encountered so it could be a faulty sensor,machine control board or also if a certain type of wash is selected it wont use any cold water at all during the whole wash cycle
Mar 13, 2010 | Washing Machines
Have a Maytag washing machine MAV7600AWW.
sometime not always it wont spin also the water temp is more on the cold side
Aug 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Warm water out when cold only button pressed. need part # for water solenoid
u can call any maytag store they can look up part but u can use the universal valve part no is 205613
Apr 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Need to set the washing machine for hot cycle, cold rinse
In owner's manual, go to Machine Information/Care and Cleaning/Cleaning the Inside of Your Ecosmart for a total hot water wash fill:
Press POWER button
Press and hold Favorite button for a few seconds until you hear two quick beeps.
Select Permanent Press cycle.
Select HOT wash. (Yes, you can do this in this mode.)
Press Favorite again to store the selections.
It really works!
Sep 09, 2008 | Fisher and Paykel GWL11 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
140 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
