Question about Fleco Professional Karaoke System Shelf System
Need source for basic assembly info on FLACO CDG - 11.
Where can I find an internal board to board connection chart (sketch) for Fleco CDG -11?
    Problem Solver:
  • 9 Answers
Fleco is out of business. They offered NO support when they were in business.
The machine itself is a good one when it's working. If the upper unit is out your best bet is to replace it with another unit (using the existing box speakers and amp). If the Amp is the problem it can be repaired by a competent repairman That's willing to take his time. Schematic is not available. I repaired my own amplifier. The biggest problem is capacitors and little 8pin op amps. The parts are dirt cheap and available from several sources. (Mouser and Digi-key)
Posted on Jun 13, 2009
I need fleco karaoke cdg-11 manual
Try Googling (fleco)(cdg-11)(manual) without parens.
May 30, 2017 | Fleco Audio Players & Recorders
Raspberry Pi: Server -- The Basics
Daniel, the only good info. I can suggest is to google (constructing a 15 board server) or Raspberry Pi: Server -- The Basics lots of info. on the net.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 30, 2016 | Computers & Internet
Is their a internal battery in sitex colormax 11
Yes. There is a battery backup to store memory. Read all about the Sitex Colormax chart plotters here:
http://www.si-tex.com/product_manuals/Chart-Plotters-3-08.pdf
Apr 28, 2014 | SI-TEX COLORMAX 11 GPS Receiver
F 11 fault
F-11 error code is a communication error between the main control and the motor control. I recommend unplugging the washer and removing the access panels. Then check the electrical connections on the main and motor control boards. After the connections are checked, replace the panels and check the operation. I have added the information on the Fdl error code because it is usually associated with the F11 code.
The FdL fault code indicates that you have a problem with the door lock assembly. This is often caused by a failed door lock but it can also be caused by a failed wiring harness connection or in some instances by a failed control board.
Check for damage to the door hook on the washer door and look for anything that could be clogging the catch on the door lock assembly on the front panel of the washer.
You may need to check the wire harness connections on the door lock assembly. The images below show the procedure for accessing the door lock assembly on this type of washer. Be sure that you unplug the washer before accessing internal components.
I have seen the failure be caused by a door lock and a faulty machine control board. A little trick I have found is to remove the top of the washer and push down lightly on the connector that is labeled dls5 this connector should have four black wires. This connector is located on the machine control board under the top. Use an insulated screwdriver to push on the connector and start a cycle. If the door locks and the washer works, I recommend replacing the machine control. It has a bad solder joint on the board. We often see error code F11 also with bad solder joints on the control board. If pushing on the connector did not make a difference, I would suspect a faulty door lock first.
I hope helps (remember to rate this free answer).
Jun 22, 2011 | Washing Machines
I need to replace the driver and passenger side mirrors on a 1990 Ford Mustang. They are power windows. Any suggestions?
Yes,
1.- You may go to a dealer and they will do the job, for a significant price.
2.- If you have the tools and the practice to assemble or dismantle mechanical parts, this will be an easy one for you.
You have to remove the interior covering on the doors, One at a time. Bring the glass up to close the window to have a better space to work and identify the wires and connections that drive the mirrors. Make a simple sketch on the colors of the wires and their points of connection, you can even leave little pieces of masking tape, with a sign on where it has to be connected.
Once you have this done, dismantle the wires and the nuts and bolts that keep the mirror in place, putting them back into their place to make sure they will be at the proper place when assembly will come.
Take the whole old part to the dealer or a similar replacement source and open the box, to make sure that you receive the very same part. Go back home and follow your assembly colors and numbers according with the sketch you have. Attach first the solid supports, using the same bolts and then connect the cables properly, following your masking tape notes. when wires are ready, turn on the switch and test if the mirrors are moving smoothly or if some wire was not at its proper place. Place the covering parts back in place and test everything again. Do the other door.
You are ready.
Good Luck...!
Apr 11, 2011 | 1990 Ford Mustang
The TV will not power on and the red light blinks 6 times.
This is a basic blinking error code table:--
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
But in most cases the power cord is "defective" as it's a common issue.try with new cable 1st or else follow the chart and replace the part as per coding chart on main board.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Panasonic TH-42PX60U Television
Drawing in Visual Basic 6.0
Hi - You cannot scan directly into VB6 unless you use a third-party control (OCX). You would need to get the data into a database table and use ADO, or, hard-code the data directly into your source code. You can actually grab it from Excel too but that involves automation programming - not hard to do - just more to learn. Have fun!
May 12, 2009 | Microsoft Visual Basic Enterprise Edition...
FLECO CDG-11 KARAOKE
All signals go through the key change board. Electrolytic Capacitors (470 Mfd) on this board were bad - REPAIRED
Nov 16, 2007 | Fleco Professional Karaoke System Shelf...
Fleco Professional Karaoke System Shelf System Logo
179 people viewed this question
Top Fleco Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fleco Audio Player and Recorder Expert? Answer questions, earn points and help others
