Question about Kenmore 62602 Electric Dryer
Try to turn on but it wont stay on
When we press the start button it turns on for a moment. if we jiggle the start button sometimes it stays on. More offten than not it goes off after a fews seconds. every once in awhile it stays on thru the whole cycle
  • twscrap Feb 16, 2009
    I have the same issue, posted earlier today. One suggestion was the timer motor, but still need more specifics on how to confirm as a new timer motor is ~$100.
  • kiwimax Feb 27, 2009
    dryer will not run unless you gently pull on the timer knob... if you let go it will sometimes continue to run ... but often not problem does not seem to be in start button
  • Kenmore Master
  • 8,220 Answers
If that dryer has a 4 wire start switch which simply twists a quarter turn to get off then replace it.
Posted on Feb 26, 2009
Pressing the on button machine turns on momentarily but does not stay on. Turns off the moment you take the pressure off the start button
Change motor the centrifugal switch in the motor is not closing when the motor turns this is what keeps the electrical circuit closed to power the motor
Mar 22, 2014 | Roper RES7646KQ Electric Dryer
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
Dryer does not stay running. Press the start button and sometimes it starts and sometimes not. Won't stay running. Seems to heat ok. Sometimes displays E9E on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Car turns but won't stay running
Check fuel pump fuse and all other fuses, check brake switch, Also, a worn ignition switch will cause the car to start sometimes but not always. Try turning the switch to on position, then jiggle the key around in the switch while pushing in a bit...now start the car...did it start? If yes, replace switch and/or key cylinder....
Dec 03, 2017 | 1991 Honda Accord
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
The screen wont turn on anymore. the buttons can sometimes but the screen stays black.
When you say the buttons "sometimes" lite up, do you mean just when they feel like it or only when you power it up or off? And is it making any noise when you power it up? If they're only working when you turn it on and then they go off, then you have a firmware problem and you need to have it re-flashed.. If they turn on and stay on, and it makes noises (like you can hear the keytones when ya press them) then it has got a bad LCD and that's a pretty inexpensive fix (check Ebay for a replacement screen)
May 20, 2009 | Motorola Cell Phones
Low battery, wont' charge in car
I pushed the reset button, on the side,during the brief moment that it stays powered up. Now it is staying on with the wall plug.
I'll let that stay on for a while and then try to keep charging it with it turned off.
Aug 10, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Wont stay on
I suggest removing the battery when plugging it to the wall outlet or are you trying to charge it? I think the one that is spinning is the hard drive reseat it then lets see what happens try to purchase a new hard drive if problem persists. please indicate also the status of the lights on your laptop ill reply with more steps when you've indicated everything
Mar 22, 2007 | Dell Inspiron 1100 Notebook
Kenmore 62602 Electric Dryer Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
