Question about Apex Digital GB55HD09W 55" Rear Projection Television
My APEX GB5108 tv sounds quit. Sat overnight and started back working. It does this off and on over the last few months. What circuit board do I need to replace? The AV board assembly, p/n 8667200540T???? Thanks, JOhn Evans
  • John Evans Feb 16, 2009
    I performed a hard reset and TV sound still did not work when I plugged in and turned it on. However, when I changed channels sound started working. Same old problem. I believe it is a bad PCB sound(card). I want to know what the card would be named or p/n so I can find a replacement. GB5108 rear projection made in May 2002. Many thanks.
  • Apex Digital Master
  • 19,396 Answers
Inspect the AV board to find out if you have a bad solder joint in there , and solder it back.
If you really need to replace teh part , you can get it for $70: 8667200540T.
Here all parts for your TV.
Posted on Feb 16, 2009
    Master:
  • 848 Answers
Hard reset - Just unplug the power cord leave the unit disconnected for 30 minutes and plug the power chord to the unit and it resets the unit ......
Posted on Feb 15, 2009
Tv will turn on but no picture and sound.
If its still both picture and sound there is a few things.First your T.V. could just be mallicous and could be trying to kill you via annoyment.Not likely.The second is the cords in the back are mixed up.Usually they are in the colors of Red White and Yellow.If they are in the wrong analog slots then even though they are plugged in,they wont work.Or it could be age,frayed wires,or any number of things.Hope it helped.
Oct 08, 2009 | Apex Digital GB5108 51" Rear Projection...
My Apex GB43HD10 pictures disappears after a while, sound works.
possible solder connection in the powersupply needs to be
resolderd it shouldnt cost much
Sep 15, 2009 | Apex Digital GB5108 51" Rear Projection...
My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Aug 25, 2009 | Apex Digital GB5108 51" Rear Projection...
Wavey lines apex 5108 projection tv
The problem can be the convergence board, or a problem with one faulty component on the main pcb.
Here you can find replacements, if you do not find your model in list call them at 1-866-925-PART (7278)
Sep 03, 2008 | Apex Digital GB5108 51" Rear Projection...
NO SOUND FROM MY APEX GB5108 TV
I had the same problem with mine, it turned out to be a fried audio board. I simply used the audio outputs on the back of the tv to drive a new reciever with surround. Sound a heck of a lot better than the speakers built into the tv.
Aug 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
55 apex HD tv
The APEX and most rear projections are notorious for poor solder joints. The convergence circuits on your TV get very hot and the solder joints weaken over time. In your case, the convergence STKs are the large chips mounted to heat sinks right up front on the left hand side circuit board. Remove the board and resolder the STKs using a good low wattage iron. If this doesn't fix your problem try replacing the STKs. They aren't that expensive. They have 15 or so legs so you'll need some skills removing them. Good Luck!
Sep 28, 2007 | Apex Digital GB5108 51" Rear Projection...
SOUND NO PICTURE ONLY RAINBOW
I just fixed this problem on my neighbor TV. I don't have a manual or schematic, and didn't pay any attention to the reference designators, so I will just have to describe it. The problem was a bad solder joint. Visible thermal fatigue. Looking at the main board, (didn't even need to slide the cassis out). There is a small, narrow, vertical board in the center, adjacent to the yoke connectors with a funny looking little transformer on the very top. Check the connections on that.
-John
Dec 15, 2006 | Apex Digital GB5108 51" Rear Projection...
APEX TV problems
need flyback transformer #030531-5283
Nov 05, 2006 | Apex Digital GB5108 51" Rear Projection...
Apex Digital GB55HD09W 55" Rear Projection Television Logo
Top Apex Digital Televison & Video Experts
Alan Timperley
Alan Timperley
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
