Question about Kenmore 18.9 cu. ft. Top Mount Refrigerator
Water leaking from the frig and ice build up inside of frig
Every week we need to clean water out of the bottom of the refrigerator and ice builds up in cavity below the freezer.
  • Anonymous May 08, 2009
    but I do not have a defrost timer on my unit.
    Genius:
  • 1,198 Answers
Your defrost is not working. First find the defrost timer, make sure it is working. Mark the little dial and wait a half hour or so to see if it moves. If you do have to replace the timer, you may still have to do a manual defrost, the ice in the freezer can take a long time to melt out. If your freezer does not come apart easy, you can turn the timer to the defrost spot(it will click and the compressor will stop) a few times until no more water comes out of the freezer drain tube to the drain pan. You will then feel good air flow out of the freezer fan. If the freezer drain is frozen up, which happens on my fridge it will take all day for it to thaw. That's why I have to take my freezer all apart, a real pain.
Posted on Apr 29, 2009
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Good afternoon........ I have a top mount frig.. we bought it in 1998. The frig works great..... The only problem we have is water seems to built up on the inside bottom of the frig.... I know it is not...
Hi Dan,
It sounds like you have a defrost drain issue. An annoyance to say the least. To repair you will need to clear the defrost drain as it can get a build up over a few years of use. On a top freezer model you will need to unload the freezer and remove the back panel, be sure the power is disconnected by unplugging the refrigerator.
With the back panel off you will see a set of coils that resemble a radiator in a car, below that coil is a pan that slopes to a hole the size of a dime, you may not be able to see that hole due to the ice build up. Clear the ice with hot water and towels to clean up the mess. Careful not to use anything sharp or damage the coil.
Once the ice is gone use a turkey baster to flush hot water down that dime sized hole until it flows clear, you will know when it is.
Reassemble and enjoy a water free frig.
Apr 18, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Bottom frig is not cold enough. just connected after 1 yr
Ok do this. Boil some water in a pot then use that to defrost the freezer. This is caused by ice build up in the vent that is keeping the cold air from coming into the refrigerator. Make sure it is defrost completel though cause the ice that is built up is mostly inside and can't be seen. That will solve ur problem I guarantee. Then set the temperature to normal. Like half way. This keeps the frost from building up. Believe it or not as refrigerators get a bit older they actually get even colder and therefore frost build up is more likely. Since no refrigeration can be made completely leak proof, small amount of the freon has leaked out older fridge, and this actually cause it to get colder. You don't need a service technician just defrost then set to a lower setting thats it.
Feb 11, 2010 | LG LRTC19314ST Top Freezer Refrigerator
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Water in the frig and possible overheating
clean the coils and check to see if the condensor fan is working. Call your local dealer and ask them to order you new o-rings for the filter mount to fix the leak from the filter.
Jul 19, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
127 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
