Question about HP DeskJet 5652 InkJet Printer
Message "Black cartridge is not compatible with this printer"
Hi, my problem with the hp deskjet 5652 is the following. The printing went without a problem one day and the next day it did not work and I received the massage "Black cartridge is not compatible with this printer“. I had not changed the cartridge in between nor had I ever refilled the existing one or used any other than than the hp ones for this printer. I cleaned the contacts in the printer and on the cartridge with cotton buds and a drop of water on the buds and clean dry buds after that, then with a dissolvant for optical appliances, took the cartridge out several times, put it in again, switched the computer and the printer off and started it anew. Then I put in a new cartridge - but nothing helped - I always get this message. Can't even see how much is left in the cartridge because when I try I receive the message "Unexpected error 1517". The printer has worked for years without any technical hickup at all. I would be so grateful for any advice or ideas!
My problem is i upgrade my operating system from windows xp to windows vista and my printer ishp deskjet 5652. whenever i print my documents it became smaller the actual size. may i know how can i solve it.
Posted on Feb 18, 2009
I can't close the lid on hp deskjet 5652 printer
try removing all ink and one by one just make sure it is all the way in securely. if that does not help its most likely you are closing the doornto fast or on an angle which prevents it from closing properly. hope this helps.
Apr 19, 2012 | HP DeskJet 5652 InkJet Printer
I have Hp Desk Jet 5652 printer. Black and color there are still ink left. Only blue and yellow prints on paper. I raced several times a cleaning program but nothing happens. Is there in printter some kind...
Hi
May be your late to refilled it and the ink dry
when that problem happened to me I put the ink in hot water
if the ink refill that's don't matter
try that and if that don't help you change the ink
Apr 25, 2011 | HP DeskJet 5652 InkJet Printer
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
HP 5652 And Windows Vista
You know for sure that the VISTA driver is the correct and most updated on for your printer and version of VISTA, 32 or 64?
http://h10025.www1.hp.com/ewfrf/wc/product?product=304442&lc=en&cc=us&dlc=en&submit.y=4&submit.x=6〈=en&cc=us
Feb 11, 2009 | HP DeskJet 5652 InkJet Printer
5652 and Vista - duplex print not working
In Vista the default s the duplexer is "not installed". Go to Start, Settings, Control Panel, Printers, double-click on the Deskjet, Printers, Properties, Device Settings and set the duplexer to "Installed".
If the duplexer prints the back side upside down in Vista once it is enabled you can get a patch as described here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Feb 19, 2008 | HP DeskJet 5652 InkJet Printer
HP deskjet 5652
Well, one way is to just take the paper out when it tries, and when it gives you an error message tell it to abort the print. Another way is that the second it starts printing press the power button, or cancel button if it has it, that will tell the printer to stop printing.
Aug 02, 2007 | HP DeskJet 5652 InkJet Printer
HP DeskJet 5652 InkJet Printer Logo
295 people viewed this question
Seeker5211
Seeker5211
