Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Water will not spray out and pick up
Will not work help
  • 1 more comment
  • Anonymous Apr 02, 2009
    will not spray are **** up water are cleaner
  • bklosu Apr 06, 2009
    water will not spray out
  • Anonymous Apr 28, 2009
    My unit won't spray any liquid. Don't call Bissell, they'll send you 200 miles away for repairs.
My steam vac wont spray out the cleaning products.
Posted on Feb 28, 2009
2 Suggested Answers
  • 48 Answers
SOURCE: will not spray the water
if this is a new model take of the handle ,If you look down were the handle plunger fits into machine you should see a valve.
press the top of the valve in ,if the machine sprays water then the fault is the handle plunger is not making full contact with the valve, ad a small pad to the end of the handle plunger ,
this should make the machine work
Posted on Nov 18, 2007
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
Won't pick up water from the clean water side
I couldn't view u'r clip but it seems if the pipe is blocked try to remove the blockage by using a hose where you spray hot water and normal dishwashing liquid, through the pipe, to unblock it. Just do not immerse the whole machine in water! Because I do not know what machine you have. Good luck my friend!
Mar 23, 2013 | Vacuums
I have a rainbow aquamate carpet shampooer. I cannot get it to pump carpet cleaner.
If it is the one with the big white water supply tank, it needs to soak with water in it for a few Days, then it may take a little bit of running,(10 minutes at the most, at a time, then let it cool, for 30 minutes in between attempts) while you are spraying water out. Make sure the soap control is on the soap bar with suds around it, and not the soap bar that is crossed out. If it is spraying water, you can keep running it. The 10 minute limit, is only if it is not spraying anything.
If it is an earlier one, it has a clogged soap pick up tube, or the soap control cap thing on the end of it.
If it is the latest big blue one, it never will probably work again. All of them must be flushed out after usage before storage, and the new one must have both, the soap and the water passages on the unit sucked out by the Rainbow vacuum, before it is stored. I have never got one of them to work again, once that it was clogged up, from not being cleared out, like it is supposed to be before storage of it.
If you need more help, let me know,
Ralph
Dec 31, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My Bissell Pro Heat Pet will spray water but not pick it up when cleaning the carpet. Is there anything I can do to fix it? The furniture attachment hose picks up water well. It seems like it could be a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 13, 2010 | Bissell Vacuums
It won't spray water and then pick up
Take the water tank off, you should see 2 spraying nozzles. You need to get to these and clear them out with a needle or something. Did the trick for me.
Could also be the pump. Check this by seeing if the hand tool sprays water.
Sep 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My steamvac will spray out water
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Pet hair and dirty water back on carpet
If you have followed the instructions.And your not happy i would return it.Get a repacement.
Aug 08, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Steamvac quit spraying
Check the seal that the clean water tank sits on, may have come loose. The filter inside the dirty water tank has been pushed up too far, needs to have a 1/4 in. gap from the top to the top of the filter.
Sep 12, 2007 | Hoover F7431-900 SteamVac Vacuum
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
576 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
