Question about Maytag MSD2454G Side by Side Refrigerator
Freezer side door opens when large refrgerator door is closed
We have a model msd2454grw side by side refrigerator we bought at LOWE'S. It was purched 11/05/01. When the large refrigerator door is pushed closed the freezer door opens and stays open unless it is noticed that is open and is pushed closed. I have cleaned the perimeter of the freezer door and around the gasket but it still happens. It appears that if the door is held closed by a magnet it has somehow gotten weaker. Please provide a solution as we have alredy lost food because it thawed when we did not notice the freezer door was open when we went on vacation.
  • 1,314 Answers
No promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Posted on Feb 15, 2009
How much does this model weigh?? (MSD2454GRW). Just bought one 2nd hand now need to transport it it home. Any advice on how to lift it into back of pickup truck??
its a model not made anymore but most weigh between 200 and 450. the more gadgets, the more it weighs. It is a side by side so id guess around 250-275, youll need a couple hands
May 18, 2011 | Maytag MSD2454G Side by Side Refrigerator
Maytag Model MSD2454GRW side by side - the refrig door is not sealing tight about halfway down the door. Is there a adjustment I can make to help to door seal properly?
Check to be sure the frig is sitting level. You should have leveling adjustment on each side below the doors and behind the grille. Also, on the bottom door hinge (usually fridge side) should be an adjustment to raise or lower the door to align the doors. After that if you simply have a deformed seal you can try carefully heating the seal with a hair dryer to soften it and should smooth out the wrinkles. Be careful not to over heat the seal. Good Luck
Mar 12, 2011 | Maytag MSD2454G Side by Side Refrigerator
My freezer door pops open everytime i shut my refrigerator door
Good day,
First, make sure the gasket including the bottom is clean, as well as the mating surface of the machine itself.
The machine itself should be checked for being level. Side to side, if it's a top freezer model, the hinge side cannot be lower than the other side.
As well, front to back it should be leveled but with a slight tilt to the rear to assist in closing.
If none of this helps, then the magnets in the gasket itself have gotten weak and the gasket needs replaced.
Notes: Heavier items keeped in the freezer door will help to a degree. Closing the door slower as well.
The reason this happens, is that with the main door open, then closed, a large volume of air is forced into the fresh food compartment. There are vents that are open between the freezer section and fresh food compartment. This large volume of air when closing the main door is compressed into a smaller area, causing the problem.
Feb 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Jun 05, 2009 | Refrigerators
Kitchenaid refrigerator side by side, refrigerator door will not close on its on like it use to. Model #KSRS25qDWH01 bought in 1996. If we give it a push it closes fine. But it use to close nearly b
order a cam and stop for the affected door. it is on the top of the hinge and the bottom of the door, you'll see the two pieces if you look where the door contacts the hinge, call a dealer for the correct part numbers.
May 04, 2009 | KitchenAid KSCS25FKSS Side by Side...
Upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
No water from door outlet
Hi. Thanks For The Question. I Would Check The Water Valve. Disconnect The Water Line From The Valve ,Leaving The Water On. Now Push The Water Button. If Water Flows You Have A Blockage. If Water Does Not Flow. Replace The Valve .Thanks The Appliance doc
Oct 02, 2008 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
231 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
