Question about Sony STR-DE597 Receiver
Dark display on Sony STR-DE597 receiver
Some time ago, I took the unit out of the cabinet for cleaning. When I put it back, I found that the tuner readout display was dark - nothing whatsoever. It seems to work fine otherwise, but is pretty difficult to use like this.
It's probably not worth taking in for repair, but I also hate to have to replace it. Does anyone have any suggestions on how to revive it??
Thanks!!
  • 336 Answers
Check for bad solder connections on the display itself. If none use a voltmeter and check dc voltage on the first and last pins of the display. should be about 20v dc. If you don't have the dc voltage check for a bad transistor or resistor in the power supply. It could also be other thing but this is where you should start.
Posted on Feb 24, 2009
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
Hi. my sony STR-DE 597 go in protect mode. how can I fix/repair this? Give me a tips.
protect mode means there is a shorted components inside your reciever it's probably the out put transistors take out the transistors and test it with a multimeter.
Jul 11, 2011 | Sony STR-DE597 Receiver
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Sony STR-DE597P - Centre Sound Problem
HI...
You have a "ground loop" problem.
It's related to the AC wiring in your place.
I dont know if you have a Walmart or Home Depot type store near you but,if you do, go to one and ask for a AC circuit tester. Should be a 3 prong unit with LEDs. Plug one into where you have the stereo and see what it reads.
You might have lost a ground connection in the AC outlet
Jan 13, 2009 | Sony STR-DE597 Receiver
Need a remote for for Sony STR-DE597 Receiver.
Bad news, most every universal remote is for tv, vcr, dvd, cable box, and nothing else. you can goto sony.com or check ebay for a new one.
Dec 21, 2008 | Sony STR-DE597 Receiver
Automatic Power Up and Power Down
Its your Micro prosseser and the gost of your last dead dog...lol
Jun 24, 2008 | Sony STR-DE597 Receiver
Spot working
Hi..
It's broken internally..Yup.
Find someone local to look at it. A TV repair shop even.
NOT Sony.
Get an estimate first.
Jan 01, 2008 | Sony STR-DE597 Receiver
How do i hook up my ipod to a sony STR-DE597 6.1 channel reciever?
have u checked the COMPATIBILITY of the IPOD with your system(receiver/amplifier). the software of some models is not compatible withyour respective receivers.
Go to their sites for software upgrades.bye.
Oct 31, 2007 | Sony STR-DE597 Receiver
STR-DE597 Display is not visible
Try a complete RESET by completely switching OFF mains power and leaving for at least 40secs. before commencing a new setting-up procedure.
Let's know if this does work it back to normality!
Aug 04, 2007 | Sony STR-DE597 Receiver
Sony STR-DE597 Receiver Logo
93 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
