2002 Audi A4 Logo
Posted on Feb 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Window prblems on audi a4
Does anybody know any reason why my windows on an audi a4 (02)wouldstopworking along with locks and mirrors. please help before istartpullingit to pieces
Anonymous
Level 2:
Sniper:
  • Expert 94 Answers
  • Posted on Feb 16, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
94
Questions
0
Helped
91997
Points
285
CHECK FUSES BEHIND FRONT PANEL (DRIVERSIDE) IF THEY ARE GOOD.CHECK IF THERE IS POWER GETTING TO THE DOOR UNPLUG CONNECTOR ON A PILLAR AND TEST FOR POWER SUPPLY.IF THAT IS GOOD.COULD HAVE A BROKEN WIRE INSIDE THE DOOR JUST LIKE MY AUDI A4.(POWER CABLE CUT JUST AS IT WENT INTO THE DOOR) HOPE THIS WILL BE OF SOME HELP TO YOU....
Hello, I have a 02 A4 and my window problem is hard to explain, if I sit in the passenger seat I can't roll my window down, only the drivers side window can roll the windows down, but the actual drivers...
that is a safety feature to stop children playing with windows. On my Lexus ES330, there is a button just ahead of the driver's 4 button window control. It controls whether passengers can use windows or not on the other three doors. Consult your manual
Page 55 and 56 refers to it as a child safety switch, it is marked 'S' on the diagram and is behind your 4 switches on the right.
Child safety switch is pressed in, the
When the safety switch 'S' in the switch lights up. The window switches in the rear doors are deactivated.
https://www.manualslib.com/manual/396576/Audi-A4.html?page=56#manual
HELP! my 2002 audi a4 drivers window and electric mirrors are not working. also when doors lock on central locking the alarm doesn't arm, but then does 30 secs later also the central locking switch on...
Either a fuse problem or could be a twist in the electrical cable in the door joint . Sometimes chafes the outer core away and causes shorts in stuff like this .
1helpful
Hi, Central Locking failed on driver door, Electric front windows failed, Intierer lights only work on switch, (not on opening car door). Driver door light (low level red light) failed, electric wing...
I have the exact same electrical problem with my 2003 52 plate A4 2.0 fsi. Would be great if you could tell me if you know what the issue is also please? Email [email protected].
Thanks
Sam
check the belt tension..it might be weak and it making noise when start
2answers
Fuel Pump Fuse Number for a 1998 audi a4 2.8 quattro
Fuses: Fuse arrangement in fuse panel, behind instrument cluster, left
Fuse Arrangement In Fuse Panel 62624464
1 - Heated washer jets 5A 2 - Turn signals 10A 3 - Headlight washer (relay), illumination for glove
compartment, climate control, Automatic Transmission, instrument cluster 5A 4 - License plate light 5A 5 - Instrument cluster, seat heating, test connection
for cruise control, bulb monitor for auto-check display, Automatic Transmission display, switch
lighting, mirror switches and actuators, airbag
warning light, outside temperature indicator,
climate control 10A 6 - Central locking system 5A 7 - Anti-lock brake system (ABS) 10A 8 - Vacant 9 - Mirror heating 10A 10 - Vacant 11 - Cruise control (Automatic Transmission) 5A 12 - On board diagnostic system 10A 13 - Brake lights 10A 14 - Interior lights, reading lights, anti-theft alarm system, vanity mirror 10A 15 - Instrument cluster, power windows, climate control, automatic transmission 10A 16 - Anti-lock brake system (ABS), Anti-Slip Regulation (ASR) 5A 17 - Heated door locks 10A 18 - High-beam, right 10A 19 - High-beam, left 10A 20 - Low-beam, right 15A 21 - Low-beam, left 15A 22 - Side marker and tail light, right 5A 23 - Side marker and tail light, left 5A 24 - Wiper and washer system 25A 25 - Blower for heating, climate control 30A 26 - Rear window defogger, mirror heating 30A 27 - Rear window wiper 15A 28 - Fuel Pump 15A 29 - Engine timing 30A 30 - Sun roof 20A 31 - Tail lights, cruise control, automatic transmission 15A 32 - Engine timing 20A 33 - Cigarette lighter 15A 34 - Engine timing 15A 35 - Trailer recptacle 30A 36 - Fog lights 15A 37 - Radio 20A 38 - Luggage compartment light, central locking system 15A 39 - Emergency flasher system 15A 40 - Horn 25A 41 - Anti-lock brake system (ABS) 25A 42 - Vacant 43 - Vacant
Audi A4 02 door wont lock.
CHECK UNDER THE RUBBER BOOT,WERE THE DOOR HINGES ARE, AND CHECK FOR BROKEN OR CUT WIRING. IT IS A PROBLEM WITH THE AUDI A4
1helpful
Keyless not working & windows not going down.
LOCAL SCRAPYARDS PHONE THEM UP, E-BAY LOOK UP AUDI BREAKING AND SENT E-MAIL FOR PRICES PLUS P&P..IS THE WIRING HARNESS CUT UNDER THE RUBBER BOOT HINGE SIDE??? VERY COMMON PROBLEM..EASY TO FIX YOURSELF...HOPE THIS WILL BE OF SOME HELP TO YOU..
2helpful
Need wiring diagram 02 Audi A4 driver window, have R&r the switch
hi,i would suggest you look ay the plug connection on the harnass between the door and the body,pull back the rubber check the wires for breaks and the plug pins for corrosion,let me know,andy
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
