Question about Toshiba Satellite A100-S8111TD Notebook
Computer won't turn on
When i turn on my toshiba laptop the screen is black & there is a message that states load error press a key to restart
  • 191 Answers
You may try
1) check RAM memory, fine the memory slots at back side (in a small cover) cross chenge memories if there are two, change other memory if only one.
2) restore or reinstall your windows. if can not reinstall or backup you need change another HD to try.
is this helpful please feedback thanks
Posted on Feb 15, 2009
  • Frank Zhang
    Frank Zhang Mar 07, 2009
    is this help you fixed
  • Frank Zhang
    Frank Zhang May 15, 2009
    please take a rating let me know how much helped you thanks!
How to reset Toshiba A215 to factory defaults
You may follow the below steps to restore your Toshiba A215 laptop to its factory defaults:
Turn the Toshiba Satellite A215 computer off.
  • Press and hold the "0" key. Turn the computer on.
  • Release the "0" key when the Toshiba Recovery Wizard screen appears.
  • Click to select "Recovery of Factory Default Software" and then click "Next."
  • Click to select "Recover to out-of-box-state" and then click "Next."
  • Click "Next" on the confirmation screen to begin the recovery process.
  • Press any key on the keyboard to restart the computer when prompted. The computer boots up to the Windows setup screen.
  • Hope this helps..
  • May 20, 2014 | Dell Inspiron Mini 10 Notebook
    Toshiba satellite problems L775 can't get past "windows is loading files"
    First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
    If you able to start in safe mode then update your graphic drivers from the manufacturer site
    Let me know if it helps you.
    Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
    Jul 03, 2013 | Computers & Internet
    I have a toshiba L305-s5984 and it will not boot until i press the page-up or page-down key then it will give me a video screen. the machine apears to have power but nothing on screen. only a black...
    not sure if this will help you ...
    How to Restore a Toshiba L305The Toshiba Satellite L305 notebook computer has a recovery program pre-installed at the factory that lets users return the hard drive to its out-of-box state. Using the recovery feature completely deletes all software and options saved on the laptop, which resolves any boot up problems and removes any virus infections. The recovery option isn't accessible directly through the operating system however, and must be accessed by starting up the computer in a different way than normal. Step 1 Close out any software currently running on your Toshiba Satellite L305 laptop. Navigate to the laptop's "Start" menu and choose "Shut Down."
    Step 2 Hold down the laptop's "0" key and press the power button. Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
    Step 3 Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
    Step 4 Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again. Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
    Step 5 Use the prompts that appear on the screen to choose your region, time zone and keyboard settings. Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system....
    if this is no help to you then go to this link...
    how to boot up toshiba L305 s5984 Google Search
    Oct 24, 2017 | Computers & Internet
    How do you go about to format a toshiba l650 and reinstall windows 7
    Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
    If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
    Using Toshiba HDD Recovery Utility from the recovery partition
    In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
    You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
    To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
    1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
    2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
    Sample TOSHIBA HDD Recovery Utility screen
    Restore Original Factory Image (Recommended)
    CAUTION:
    Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
    1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
    2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
    3. Press any key to restart the computer.
    * The options 2 & 3 are for advanced users.
    Hard Disk Drive Recovery using Recovery CDs or DVDs
    You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
    Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
    restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
    Installing Drivers and Applications
    The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
    To reinstall drivers and applications:
    1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
    2. Click "Next".
    3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
    4. Click "Install".
    5. Follow the on-screen prompts to complete the installation process.
    Hope this helps.
    Jun 19, 2011 | Toshiba Computers & Internet
    How to factory restore the laptop as its been slow now and want to reset to the factory settings. I do not mind loosing data as i had backed it up
    Restore Toshiba to Out of the Box Condition
    If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
    1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
    your notebook.
    2. When the machine Starts beeping; release the 0 key.
    3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
    4. Select Recovery of Factory Default Software; click Next.
    5. Select Recover to out-of-box state. 6. Click Next again.
    7. Click Next to Start recovery.
    8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
    Apr 18, 2011 | Toshiba Satellite M645-S4065 Notebook
    Toshiba 1205-5813 will not load windows up. When power on computer and log on, the next screen i go to is a black screen with my cursor just showing
    Can you go in via safemode if so one of your drivers might be of issue.if you get in try this start run type cmd hit enter once,the dos prompt appears at the prompt type chkdsk /r.you will see a error message stating this volume is in use do you want to run scandisk on startup instead answer yes restart it will start repairing itself on reboot.Good luck
    Aug 28, 2009 | Toshiba SATELLITE Notebook A205-S5813
    Computer screen wont turn on
    Hey,
    It appears the windows installation is corrupt or the hard drive has a problem. I would suggest to reinstall from the windows installation cd or from the restore cd. If you don't have these I suggest you take the computer to a repair person who can get it working for you.
    Thanks,
    Ekse
    Feb 15, 2009 | Toshiba Satellite A100-S8111TD Notebook
    Computer only states load error
    press f8 during restart then choose last known good
    if still can't load f8 again then safemode do a disk defrag and then restart
    if you still get same error or cannot get on let me know so i can try another solution
    don't forget to rate
    Feb 09, 2009 | Toshiba Satellite A100-S8111TD Notebook
    I have a Toshiba Satellite A105
    1. Please press and hold on F8 key immediately after power on then select Safe Mode. If you are able to go to the desktop, please go to Start-All Programs-Accessories-System Tools-System Restore. Please select a date when your laptop was working properly. This will the software changes beyond that date but will not delete your personal data. Your laptop will restart and give the message that the restoration was completed. Please connect the ac adapter so that the process will not be interrupted. If this does not work like if you are not able to
    2.Do the system recovery but with this option, you will lose everything and your computer will be restored to the out of the box state. For you to do this, you will need to use the recovery disk that came with your laptop. Please load the disk 1 then turn your laptop off. Please press on the power button to turn it back on then immediately press and hold on the F12 key. Select CD/DVD from the boot options. Windows will be loading files then select Recovery Wizard. Select the Default Software after that then select the Recover to the Out of the Box State. After the first disk, you will be prompted to load the second disk. Please connect the ac adapter since the entire process will take around an hour.
    Hope this works. Thank you.
    Sep 22, 2008 | Toshiba Satellite A105 Notebook
    Problem restarting, "press r"
    1. Start the laptop
    2. when the logo screen turns black start pressing F8 a few times.
    3. A Windows Boot Options screen should show on the screen
    4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
    5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
    It "should" now load normally, if not then..
    1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
    If not, then post back with any error messages and we can look at something else.
    Apr 13, 2008 | Toshiba Satellite A105 Notebook
    Toshiba Satellite A100-S8111TD Notebook Logo
    66 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
