Network cable shows 'unplugged'
When connected to copier network cable always shows 'unplugged'. Cable test ok on all other devices.There is a printer cable hooked up and that works.Network cable did work at one time.
  • 265 Answers
What king of network cable are you using?
If your using a ethernet cable, try using a crossover cable instead. this is the prob i have come across a few time.
You can also check the printer networking settings by going to:
Start => Control panel => Printers => then left click and press propites,
this way you can check all your network connection settings for your printer.
If problem still presists, then i suggest trying to link the printer up with another system and trying the network card on that.
Please rate my solution.
Hope this helps
Posted on Feb 17, 2009
  • Alex Keen Feb 17, 2009
    Hi again,
    you could always use this USB network cable if your network will accept it
    Click here
  • 19,396 Answers
Try a different cable and ping the printer.
  • Ginko
    Ginko Feb 17, 2009
    Try also unplugging the printer from power for a while.
    If it shows cable not connected with all cable and restarting does not fix the printer then the printer network card may need replacement.
    If the problem is on computer side instead, reinstall network driver.
Would like to know why my printer always says offline
check the following steps : If the router is running ok , the network cable is properly inserted in the router or switch, cable network is ok (try another device ) tries to remove the printer configuration in case you can provide your network , do not know about.Tray to reinstall the printer is not working printer .If possible logical network card functioneze.Era not ok if it says the printer using
Feb 24, 2015 | Cannon Office Equipment & Supplies
How do I config HP L7590 Officejet Pro printer to a wired network?
skil, your usb connection is to the cpu. Go to printers and devices from start and see if this printer is your default printer. If it shows ready, it's working. Test print.
Dec 01, 2014 | HP Office Equipment & Supplies
Why doesn't my wireless printer work on my network with sharing enabled?
Do you have the printer drivers installed on the originating device? have you connected it to your network?
Jun 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
Why Does my Printer not save IP Address
if no network cable is connected then it will always show as 0.0.0.0 this is because the network connection is not activated without a network cable
Mar 31, 2014 | HP LaserJet 4250n Printer
Laptop running vista will not print wirelessly
check the cable connections, unplug replug the cable.......then turn it on
Sep 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
The network and connectivity button is not working
if the machine has been set up prior to this fault and you could print to it then the connection is faulty or the password or ip address has changed.. go to the printer panel on your desktop and right click on the printer then go to ports and check the connection mode if you have ausb connection on the printer this should show up if it is set to anything else the fault lies in the port settings.. you can also print a test page from here as well on the general settings page there is a tab for test page do this and see the result.. if no page the connection to the printer is wrong or the cable faulty. if you have a network cable look at the printer input panel .. where the cable goes in there should be two small lights on aone green and a yellow below probably of no light at the connection point on the panel you have no connection.. as a last resort uninstall the copier fron=m the server/computer and reinstall use the same ip address for the copier and you should be ok.. you might need the gateway address too if you have a hub set up.Good luck A
Aug 13, 2009 | Xerox WorkCentre Pro 90 Copier
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
CYAN ERROR
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Unable to print on printer Dell 926 -test page prints ok
PREM
May 23, 2009 | Dell 926 All-In-One InkJet Printer
Connecting printer
1. Unplug the cable.
2. Hold the Go button for 10 seconds until the network config page is printed.
3. plug the cable and try it again.
Sep 18, 2008 | Brother HL-2040 Laser Printer
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
