Question about GE Refrigerators
Ice dispenser auger does not work.
I have checked the switch that detects when the door is closed. It seems to be fine. Also, when I push the lever to dispense ice, I can hear the solenoid making a noise, so that switch apparently works. I think the problem might be the auger motor, control circuit, or wiring? Any advice is appreciated. Thanks!
  • 257 Answers
Hi, On GE refrigerators the motor is not quiet. Open your freezer, remove the ice bin, press the door switch, make sure it turns off the light, and then press the ice dispenser lever. The solenoid will click, which also opens the ice door and the auger motor will turn on and you can definitely hear it. If the motor runs then inspect the auger connection on the rear of the ice bin, its plastic and they break. On some models, like my GE Adora there is a switch just for the ice maker behind the ice bin. If you need more help let me know as with all long distance troubleshooting we try with the information we have. Thanks and Good Luck!
Posted on Feb 15, 2009
Kenmore cold spot refrigerator model # 106.56662500 ice is not dispensing through the door. How do I fix it?
This is common in these units. When the dispenser lever is depressed, an auger motor rotates the auger wire. When the auger rotates, it pushes the ice toward the dispenser door and chute. When the auger is defective, it isnt able to push the ice out of the dispenser. You need to check the auger to determine if it is broken or disconnected from the auger motor. If the auger is broken, replace it.
Jan 28, 2017 | Kenmore Refrigerators
Out loading auger problems
if by this your saying that the ice dispenser auger has a problem ?
a few things to look at on a ice dispenser
1st remove ice bucket with auger completely out of fridge
look at back of fridge is there a build up of ice there ? if so you may have a leaking water valve for ice maker
carefully inspect the back of ice bucket to see that drive catch is not broken or missing parts
2nd verify that the door to side that contains the dispenser is all the way shut , sometimes ice build up keeps door from closing all the way to allow door switch to say ( door closed safe to dispense ice) this switch is not allways at top or bottom of door but maybe in the middle too
and last but not least , make sure all switches and childlock outs are set correct to working positions and that glass sensors detect the glass in its place
Nov 14, 2015 | Refrigerators
Ice maker makes ice and dispenses to ice bucket but will not dispense from the door
Check that the motor is connecting to the drive and isn't broken. Also. Check to make sure no frozen chunks are jamming the auger
Oct 07, 2015 | Refrigerators
Kitchenaid KSRS25 Ice dispenser blades get stuck
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
Kenmore model number 253.55693400 when I push the ice dispenser tab the motor to push ice is on, but not pushing ice out.
You have an auger type of ice dispenser, so when you say you hear the motor is on, do you mean it is turning the auger? Take out the ice bin and close the door, push the dispense button and then open the door quickly to see if the auger is turning. If is is then dump your ice bin and let it sit out until it is completely defrosted and dry. Reinstall the ice bin and put the lever down. And see if that will clear the problem. The auger motor is not that strong and if you get any ice build up under the auger it will stop working. So defrosting and drying will normally clear it up.
Oct 02, 2011 | Kenmore Side by Side Refrigerator
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
The ice dispenser motor is working and turning, but the ice won't come out. It appears that the mechanism in the ice bucket is not turning or moving ice out.
Check the drive on the auger motor......the peice that turns when you push the ice lever. Open the freezer door, pull out the ice bucket so you can see the drive, tape the door button or have someone hold it so the fridge thinks the door is closed, then hold the auger motor drive while you push the ice lever on the door. Those have a problem where they get stripped out and they will turn with the ice bucket removed but if you put any kind of a load on it the drive will slip and just turn on the motor shaft.
Sep 12, 2009 | Refrigerators
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
398 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
