Question about Toshiba 61H70 61" Rear Projection Television
Tohsiba 61HD70 Rear Projection
I have a Toshiba 61hd70 rear projection. The picture has begun to distort and there is basically a rainbow effect on the bottom and top of the screen. Scrolling words will start on the left then move to the center before going back down to the right side. It does not do this all the time, sometimes the picture is working good. Does this sound like a convergence problem? How do I fix it and is it something I can do myself?
Today the picture shrunk and a bunch of lines appeared in the middle. The picture then went off wouldnt turn back on and the red power light is flashing? After shutting it off for a few minutes the picture came back on, but will still flash on occasion.
Let me know if you need more informaiton.
Thanks
    Novelist:
  • 184 Answers
Yes, its a convergence problem and you may be able to fix this yourself if you have a soldering station and a few basic tools. Its possible that all that is necessary is to re-solder the pin connections on the convergence output ICs on the underside of the cicuit board. There may also be a poor solder connection on a jumper wire connection near the ICs. Its near the plastic frame. If this does not resolve the issue, you will need to replace the ICs. Remember to unplug the TV before doing any service.
Posted on Feb 15, 2009
Hi, My friend has a Toshiba 65h84 Rear projection tv that has bad picture. when turned on it shows some snow effect but pink instead of white. when we connect the cable you can see distorted video on the...
Chances are you have a defective hyper module. The symptom with this problem is called piecrusting and appears as a squiggly and distorted picture, usually worse at the top. It may dissipate after 20 to 30 minutes as well. This module has been out of production for a few years but some regional companies will rebuild it for around $125.
Bill W
integrityhomeworx.com
Mar 14, 2011 | Toshiba 65H84 65" Rear Projection HDTV
Magnavox tv
try degaussing the screen... if your tv doesnt have that option, here are some ways to achieve that http://www.wikihow.com/Degauss-a-Computer-Monitor
Jan 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence color has a rainbow effect
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Toshiba 57H81 57" Rear Projection...
My tv has the rainbow/3d effect on the right hand side, and is starting on the left side.
Hi my rear projection tv has got a blue and yellow line looks like a rainbow how can i fix it please.
Feb 21, 2011 | Zenith R57W46 57" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Picture Distorted
You need new convergence ICs Call your locally tv repair shop or find someone that knows how to work on CRT projection tvs.
Aug 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Ctc 195 series rear projection T.V. piture quality
Can you post a picture of what the video is doing? It shounds like a pincushion problem, but it may be convergence amp as well. A picture could clarify it for me so I would know which direction to assist you in.
Feb 23, 2008 | JVC AV-56WP74 56" Rear Projection...
Rainbow
Rainbow effect has more to do with color wheel style and speed.
Jan 31, 2008 | LG RU-44SZ51D 44" Rear Projection...
Open Questions:
Toshiba 61h70 Picture Problems Hello, I have a Toshiba 61h70 TheaterView HD Projection TV, and was recently having some slight convergence issues (red was out of alignment and could not be adjusted). So I researched and found that the IC?s (STK392-110) needed to be replaced. I initially purchased them on eBay, to later find out that they were cheap clones and did not work (they made the convergence worse, actually). I then purchased 100% Sanyo IC?s from a reputable dealer and replaced the IC?s again. Once finished, I then entered the service menu and adjusted the convergence alignment. Once the alignment was perfect, I hooked back up the TV antenna, the DVD player (composite), and the S-video from my computer. The convergence is fine, but now I?m having a totally different issue ? the video is ?scrolling?. The menus will show up fine, however any incoming video inputs will show up okay for a split-second, but will then flash and the picture starts to scroll in different directions. This happens with any of the video inputs. I checked and changed all the service menu items to factory defaults, however this had no effect. I have pasted a link below to a short video that illustrates the issue that I?m having. Please note that the video starts off with a black screen, showing the ?input? menu, and then I selected the ?TV input? and changed the channels. You will see the picture fine for a moment when the channel is first changed, but then the picture will start to scroll. Any ideas of what would be causing this? And how can I correct the issue? I?m not a TV repair expert, so I?m not even sure where to start. Any help would be greatly appreciated. http://s75.photobucket.com/albums/i303/hybrydmike/?action=view₪t=TV_Troubles.flv
Feb 27, 2017 | Toshiba 61H70 61" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
361 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
