Question about Dell PowerEdge 2650 Server
Boot up for the 1st time
I have problem booting up DELL computer for the 1st time after my purchase..the power seems to go off after a while... and I am using the power adapter instead of the battery
I want to chhek & find the problem of directx on my computer
Posted on Feb 16, 2009
Dell Inspiron One 19 Black screen after dell logo boot up
Sounds like you have a video driver issue. See if you can boot from your "Dell Resource" CD or any other bootable CD disk. Power on the computer and tap the F12 key to get to the "Boot Selection Menu". Insert the "Resource CD" into the CD-ROM drive. Select "Boot from CD/DVD drive" from the selection menu. If the computer boots from the CD drive then you Operating System Software is the problem.
Mar 19, 2013 | Dell Inspiron One 19 All-in-One Desktop PC...
Dell Inspiron 2650 will not boot to Windows install CD after UBUNTU Linux installed on machine.
have you went onto the BIOS to make sure that the boot options are correct e.g. CD DRIVE 1st priority?
Aug 06, 2012 | Dell Inspiron 2650 Notebook
My pc doesnt load every time I want to turn after i boot the power and press 1st, 2nd, 3rd and 4th boot... in the screen I can see Dell is loading but doesnt move, i try to press F12 for boot and the...
Are you Sure that the computer model is Dell Optiplex GX260? Because looking at the manual diagnostic lights are found at the back. and the fault can be determine If the ABCD lights are yellow or green. But None the less 2/3 Depicts a hard drive problem while 3/4 depicts a memory issue.
Hard drive Issue:
1. Disconnect all non essential cables at the back of the computer. Leave only the mouse, monitor and keyboard. See if it boots up normally
2. If it boot up fine. try plugging one peripheral at a time until you find which peripheral causes the computer not to POST (Power on Self Test)
3. If you still getting problems, Follow these steps
4. To access the BIOS you must tap F2 or delete key upon turning the computer on
5. Try to look for the Hard drive if it is detected by BIOS if not got to step 9
6. Look for Boot Sequence or anything that is associated Boot
7. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
8. Save the changes and Restart
9. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
10. If Step 9 did not work I think you need to replace the Hard drive
Memory Issue:
1. Open the chassis of the computer
2. Try taking out all memory modules
3. Rub the metal contacts of all memory with a pencil eraser
4. If more than one memory. Put one memory first and turn the computer on. If it turned on add another memory and turn the computer on. Repeat these steps until you determine which memory is faulty or all memory module contacts needs cleaning
Jun 16, 2011 | Dell OptiPlex GX260 PC Desktop
When trying to factory reset my Dell inspiron 1525, I pressed the F8 key until the Advanced Boot Options menu appears on the screen as my computer start up. Then I select Repair Your Computer on the...
Hopefully, you have the set of CD/DVD "Dell System Restore" disks.
This might be a good time to purchase a newer, larger, faster, disk-drive, install it,
and load Windows onto it, and keep your current disk-drive as a "fall-back".
Restart your computer, and press F8, and tell the computer to boot from the first of those "System Restore" disks, rather than booting from your 'C:' drive.
Jan 20, 2011 | Dell Inspiron 1525 Notebook
DELL POWEREDGE 6400 IS NOT BOOTING FROM THE CD
Go to your BIOS and change the boot sequence so that the system boots to the CD 1st. (You should see a tab or label that says Boot Order or Boot Device.)
Good Luck
C2S
Aug 13, 2010 | Dell PowerEdge 6400 Server
When I attempt to turn on my Dell 2300 computet, I get a message saying that NO BOOT DRIVE DETECTED AND MUST PUT IN WINDOWS DISC AND HIT F1 TO REPROGRAM COMPUTER. I have already reprogrammed the computer,...
Sounds like the boot order in the bios is wrong, go into the bios, change and SAVE it, dont just exit without saving.
If you still get problems, get a new cmos battery,
I always have cd/dvd rom as 1st boot then Hard drive, and disable other boot devices
Jul 26, 2010 | Dell Computers & Internet
Need step by step instructions to reinstall XP home edition recovery CD on dell 4400 32 system is damaged and I can not open anything
Insert your System CD (the one with the operating system on it). Boot up the computer and press F12 during the couple of seconds at the very beginning of the boot sequence to access the boot menu. You'll want to specify the CD-ROM as your 1st boot device. The system will boot from the system CD and you just follow the prompts to reinstall the operating system. Just realize, this will restore your computer to "out of the box" condition. You'll have to update Windows XP several times as well as your drivers. Also, ALL data that was on the computer will be lost forever.
Mar 18, 2010 | Dell Dimension 4400 PC Desktop
My Dell E193FP boots up with the computer and then
Seems to be a very common problem with this screen. Im taking one apart as we speak to try to discover the problem. In the mean time - check that the Power Input isnt loose, and you can wiggle it around. Usually means the power is arcing onto the board
Sep 01, 2009 | Dell E193FP 19" LCD Monitor
Alert! previous attempts at booting this system have failed at checkpoint [WRIT.] -- Optiplex GX270 Dell Computer
I'm not sure right off hand what the WRIT means. But other articles online seem to think that you should hit F2 at boot and check the Boot Order. One guy set it to CD and booted a CD (a bootable one) fine. I would make sure it set to the first Hard Drive. He also said something about: went to the "event log" section and cleared the last event (actually the only one showing). I saved the settings, then booted up again and this time it booted up normally.
* Anyway new hardware external or internal would be 1st suspect in this kind of thing. One person had problems after adding a new printer that had a memory card in it. Apparently the Dell tried to boot from the memory card.
Jul 07, 2009 | Computers & Internet
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
Dell PowerEdge 2650 Server Logo
129 people viewed this question
Alun Cox
