Question about IBM NetVista PC Desktop
My pc won't read the network cable adapter cord.
My cord is plugged in, my network is running. But for some reason it keeps saying it's unplugged becuse it's firewalled. how do i remove this?
  • 4 Answers
Next to the plug in is an LED light. If it is not lit then the cord or the network card is bad. a fire wall should not give a cable disconnected message, maybe a limited connectivity message.
Posted on Feb 15, 2009
How to fix no power
Check for disconnected computer power cable connections. A loose or unplugged power cable is one of the top reasons why a computer won't turn on.
Laptop & Tablet Tip:Even though your computer runs on a battery, you should make sure that the AC adapter is plugged in properly, at least during troubleshooting. If you regularly keep your computer plugged in, but it has wiggled loose and now you're battery is empty, your computer may not be getting power for this reason.
Dec 16, 2014 | Computers & Internet
Hiro h50015 nic on windows 7 says network cable unplugged when cable is clearly plugged in
To connect to the internet, you must have a device like a modem or a router. Is your PC connected to this device? Do you have other PCs or networked devices on your LAN? Can you reach them with ping?
To make it easier to help, you should give information how your network looks! e.g.
internet ---- cisco800 router --- d-Link switch ---- myPC
or something like that. Otherwise it is fooling around in the dark.
Apr 13, 2014 | Hiro H50015 Network Adapter
Gateway Gt 5220 computer will not connect to internet
Open the Device Manager, Network Adapters, Is the Ethernet adapter enabled? Do ALL your Windows and Gateway updates. Your Ethernet driver can be found here, select your OS, 32 or 64 bit : http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2890
Feb 13, 2013 | Gateway GT5220 PC Desktop
I was just kind of chilling on my laptop most of the day. And it kept like running outta battery like it normally kinda does every now and again. I kept it plugged in most of the day but it wouldn't...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Dec 28, 2010 | Computers & Internet
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
When I connect the wrt160n in the pc it says network cable unplug
Check the Ethernet adapter status under network adapters in devicemanager.
right click my computer-properties-hardware tab-device manager-network adapter.etherrnet should be green
Jul 12, 2009 | Linksys WRT160N Wireless Router
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
COMPUTER SHUTS DOWN
Possible solutions:-
1:) Faulty Ethernet Card or Slot on motherboard. Possible sharing violation.
2:) Faulty-Broken-D Cable.
Solution:- remove card, and insert into another vacant PCI Slot.
check cable for kinks or breaks.
Mike @ Compurepair.
Jul 23, 2008 | HP Pavilion A610n (PC106A#ABA) PC Desktop
IBM NetVista PC Desktop Logo
50 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
