Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
KENMORE HE3T WASHER NEW BELLOW
NEW BELLOW WAS JUST INSTALLED AND AFTER 2 WASHLOADS CLOTHES STARTED TO RIP AND BELLOW IS STARTING TO WEAR AND SHREAD FINE POWER LIKE PIECES. ALSO THE TOP SPRAYER ON TOP OF THE BELLOW IN WHAT DIRECTION SHOULD IT BE POINTING? THANK YOU
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Kenmore elite washer troubleshooting
Sounds like your bearings are worn and need replacing... a horrible job. The frayed plastic may mean a new drum. To replace the bearings you must remove and separate the drum which requires removing the top, front, and back panels. Lots of clips, screws, hoses, wires.... I'd take it on if this were my unit; but for a client, I'd say get a new one. This is not uncommon for these units. Sorry.
Feb 16, 2014 | Washing Machines
I have Kenmore Elite HE3 Front Load Model 110.5862400. The rubber gasket/bellow got wadded up with clothes and popped out along with the clamp. How do I put back together. There is no damage but I don't...
The following link explains the steps required to install a door bellow on a front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Inspect the bellow and the front and rear clamps to ensure they are not damaged. If the bellow has any rips or tears, it must be replaced or it will leak.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer can contribute to items getting caught in the bellow and causing premature wear. Follow the manufacturer's recommendations for proper loading.
Feb 04, 2010 | Washing Machines
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Worn out bellows
The bellow definitely should not deform in the manner that you describe. When you replaced the bellow, did you line it up correctly? There are alignment marks (Arrows) on the tub and the bellow to ensure it is installed correctly? If the bellow is not aligned correctly, it will twist when the tub spins. If the shocks are worn, the bellow could also deform, but you would probably experience excessive vibrating during the final spin. If you are sure the bellow is installed correctly, and wish to replace the shocks, let me know. There are four of them on your washer. I believe they are sold in pairs. If you post your complete model number (located around the door opening), I can assist you in locating parts.
Jun 20, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
KENMORE HE3T BASKET RUBBING ON THE PLASTIC FRONT TUB
if ripped obvioussly youl need to replace the front rubber bellow, i would remove the bottom panel and have a look inside sounds like you have a broken shock aborber or 2 not properly supporting tub assy
Feb 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
231 people viewed this question
Sal De
fordexpert
Robert Rankin
