Question about Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven
Frigidaire feb386wech single oven error codes
I keep getting error codes f1andf3 . I cannot find a listing of the codes, they seem to be a secret! Can someone please divulge the meaning of these codes. Is there a schematic of the control board available ? Thank you
  • 6,784 Answers
HI. the F-1 code represent s a failed oven control board. you will need to replace the clock or, oven control in this case. it is damaged.
Ok, the F-3 represents a failed oven temp sensor device. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Aug 01, 2009
I had asked the same question to help a friend out. Seeing the sensor or wire is located above the broailer, I had him carefully use a scotch abrasive pad and clean it. After doing so it then had no further code problems
Posted on Dec 04, 2011
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
Is there a sight to find frigidaire built in oven error codes
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand you are seeking a site that provides a listing of error codes on your Frigidaire oven. This information is very rare to find. Is your oven receiving an error code? If so, may I have the error code and with this information I'll be more than happy to help you narrow down the possibilities of the code. Thank you!
Aug 02, 2014 | Frigidaire Ovens
What do the error codes for frigidaire elite electri clean oven
Hello friend, thank you for your post!
I see you have a Frigidaire wall oven and you are searching for error codes. Do you have a specific error code that your oven is giving you? Also, could I get your model number please? With that additional information I would be able to provide you more assistance. I look forward to hearing from you. -Matt
Aug 02, 2014 | Frigidaire 24" Built-in Single Electric...
How do i test a control panel of a frigidaire wall oven
Good Morning Friend,
I understand that you want to know how to test the control panel on your Frigidaire wall oven, model# FEB386WECH, due to the bake element not working. I also see that you have changed the bake element and only the broil works. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the bake element is not working. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
Something popped in back and now no heat in oven. no error codes, everything seems to work, but no heat.
If it is a fan assisted oven, and the fan is working o/k, then you probably need to replace the oven element, this is located at the rear of the oven, behind a removeable cover.
Hope this helps you.
Dec 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire wall oven FSC88W-5 The door is open
i have a feb386wech frigidaire wall oven that the left door latch came out and will not latch an stay in place
Aug 11, 2009 | Frigidaire Ovens
Error codes
hi there
ur error F-30 indicates an open probe connection....
for (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
if ur not confident and comfortable abt doing this work... i suggest u call a tech....
good luck and stay safe.....
have a nice day
Jul 16, 2009 | Frigidaire FEB27S5A Electric Single Oven
I have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Jun 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire oven F-10 error
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
May 24, 2009 | Frigidaire FGB24S5A Gas Single Oven
Open Questions:
Frigidaire FEB27S6DC / FEB27S7DC Electric Single Oven Logo
312 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
