Question about Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Following a paper jam the message "unable to print 50" appeared/ print unable 50
  • 1 more comment
  • Anonymous Feb 15, 2009
    same thing happened to me i cant figure it out.
  • Anonymous Mar 13, 2014
    unable print 50
  • Anonymous Apr 01, 2014
    i don't know how to fix it..
  • 265 Answers
I have the same problem. Most people i asked about it said it is a mechanical problem. It's better to bring it to a brother service center near you.
Posted on Feb 23, 2009
    New Friend:
How to solve unable print 50?
Posted on Apr 30, 2013
3 Suggested Answers
the kowalski
  • 86 Answers
SOURCE: message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Posted on Jun 02, 2009
  • 214 Answers
SOURCE: error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
Posted on May 11, 2008
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
Aug 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brothers error message 50
Check for remaining ( small peace) jammed paper inside.
Jan 23, 2009 | Brother MFC-3240C All-In-One InkJet...
Unable to clean message
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
1.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2. If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine...
Thanks.
Dec 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to initialize
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Error messages
Good luck.
May 11, 2008 | Brother Multi-Function Center MFC-240C...
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Error message print unable 50
the encoder strip which gives the printhead the position is out of place (error 50). You have to open the printer and reinsert the strip:
Stick a 1.5 inch tape onto the printhead cover where the strip runs thru. This will prevent this accident in future!
Nov 05, 2007 | Brother IntelliFax-2480C Fax
Brother MFC 240C All-In-One InkJet Printer Logo
2,308 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
