Question about Compaq Presario 5000 PC Desktop
16 Bit Vs 32 Bit Systems
I enrolled in an old DOS Qbasic Programming class, they sent me the lessons manual and a floppy disk with instructions and installation. I have a floppy drive on my computer, but the computer won't accept the 16 bit program. I really want to learn DOS computer programming and this floppy disk is a must. Is there some way I can convert this 16 bit disk to load on my 32 bit system, or is there a way to convert this disk to a 32 bit installation disk so I can use it.? I don't think this is my first lesson. (Smile).
In a dilema already.
a-tripod.
  • 33 Answers
You can't convert the program on the disk from 16 bit to 32 bit. However the 32 bit versions of Windows are supposed to include legacy support for 16 bit applications. What version of WIndows are you running? What's the exact errormessage you're getting?
However, I would recommend that you use a virtualization product called DOSBox. DOSBox is free software that runs older 16 bit applications on Windows (And other operating systems such as Linux) very well:
http://www.dosbox.com/
Posted on Feb 15, 2009
Testimonial: "worked great, thank you"
What does code 7f mean on kv8 pro
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code: http://www.manualslib.com/manual/615/Abit-Amd-Athlon-Kv8-Pro.html?page=69#manual
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
May 23, 2014 | Abit KV8 Pro Motherboard
How do i get floppy disk to run on windows 7..
Your computer is running a 64 bit Operating System. This means it is compatible only with 64 and 32 bit software. It is extremely likely that the floppy disk your are trying to use contains 16 bit software which was common in during the era of floppy disks.
The solution is to use VMWare, Virtual Box, or similar software to virtualize a 16 bit compliant operating system.
Jul 27, 2012 | Sabrent sbt-ufdb SBTUFDB USB external 3.5...
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
I FORGET MY IBM THINKPAD LENOVO T60 BIOS PASSWORD, NOW HOW I ENTER IN BIOS. PLZ GUIDE ME. S.VIRANI
Hi
Remove to your BIOS password download the CmosPwd, and follow the mention below instruction.
Typical Usage for DOS and all Windows users:
1) Identify your BIOS manufacturer (usually displayed at boot-up)
2) Start in DOS, or start a DOS session in Windows 95/98/ME. For Windows NT or Windows 2000 boot from a DOS or Windows 95/98 boot disk (you can find boot disks at www.AnswersThatWork.com), and run CMOSPWD from your boot floppy (or another floppy).
3) C: [Enter] cd CMOSPWD [Enter]
4) Type CMOSPWD at the DOS prompt and press Enter.
5) CMOSPWD will display a list of possibilities. Use the possibilities itemised against your BIOS manufacturer. Remember :
a) For AWARD BIOSes, use the Numeric Keypad (with NumLock ON).
b) AWARD 4.50PG BIOS always accepts "AWARD_SW", or "d8on", or "589589".
c) Old Phoenix BIOSes will accept "phoenix".
6) If the standard method does not work, then try to kill the CMOS password with CMOSPWD /K (and press Enter), and then see if you can get into the CMOS without a password. If you can, you successfully "killed" the old CMOS password. DO NOT KILL THE CMOS ON LAPTOPS!
Aug 03, 2011 | Computers & Internet
Dosn't work with windows 7
Broderbund's ClickArt 200,000 Image Pak should install quite easily on a 32-bit version of Windows 7.
64-bit version of Windows 7:
It is not possible to install ClickArt 200,000 Image Pak on a 64-bit version of Windows 7 - because the Setup.exe file is not compatible with any 64-bit Operating System. That is due to the fact that the Setup. exe file contains 16-programming code. 64-bit Operating Systems cannot handle any 16-bit programming code.
Hope this answers your query. Cheers!
May 03, 2011 | Broderbund Clickart 200,000 Image Pack for...
What is best website to show me dos programming examples.. want to creat an exe file to pick up text files from a directory and send them to a printer whenever a new file appears .(without pc...
you mean a .bat file that can be run when a new file is added. let me see if i can find a good site for you.
http://www.chebucto.ns.ca/~ak621/DOS/BatBasic.html
My advice is get a good book! One that stands out in my mind is "The Waite Group's MS-DOS Bible" (1991?) This will take you through using the command shell and batch files through how the DOS filesystem is structured, memory managment under DOS, an explaination of how the OS loads a program up to wrting little progams of you own using machine language and debug.
Another great book is Dan Gookin's "Advanced MS-DOS Batch File Programming" that will also teach you something about operating systems in general in a nice, unformal tone.
DOS also comes with a BASIC interpreter called QBASIC, that can teach you the funamentals of programming while augmenting your shell scripts and doing things that plain batch files just can't do.
www.animatedsoftware.com/faqs/learndos.htm
Aug 03, 2010 | Microsoft Windows XP Professional
Turbo c not working....16 bit ms-dos subsystem error
There have been several changes in the way programs work. Windows xp does not
allow direct access to hardware resources to protect system integrity.
However you can try a few things
http://support.microsoft.com/kb/314106
http://support.microsoft.com/?id=165214
http://support.microsoft.com/?id=324767
Generaly speaking this error shows up when a program tries to use a
command.com file from an incompatible version of windows.
Alternatively login in safemode and use. it ll work fine. rate this!!
Aug 15, 2009 | Borland Turbo C++ 4.5 Full Version for PC
16 bit MS-Dos Subsystem Turbo C++ IDE The NTVDM CPU has encountered an illegal instruction cs:0000lp:flboop:of00640352 choose close to terminate the application
I too have a problem on my PC,when running the Turbo C programThe error message is:
16 bit MS Dos Sub system
turbo c++ IDE the NTVDM has encountered an illegal instruction.
At last i found the solution, and it is simple.
After installing your turboC follow the steps..
1) go to TC directory and open BIN.
2)In "BIN" folder you can find "tc.exe". Right click on "tc.exe" and click properties (and make sure that do not click on shortcut of TC.exe).
3)In properties there should be a tab called "screen", In that you will find "usage" option. There.. select "window" option instead of "full screen".
4) Then click "OK".
5) Now click "TC.exe".
6) It will open in window mode, if you want you can change full screen mode by pressing "ALT + Enter".
Thanks & Regards
Shravan reddy Konnela.
Jun 02, 2009 | Microsoft Windows XP Professional with...
The ntvdm cpu has encountered an illegal instruction
I took this from another web site:
Michael Chiew said:
What did you do before this happened? What were your last deeds on the machine before the pop-up appeared?
I think what you're referring to is NTVDM CPU, not NTDVM CPU. Am I correct?
What do you know about 16-bit and 32-bit applications? Well, 16-bit applications are those that must work within the DOS (Disk Operating System) environment, a real-mode arena. NTVDM stands for NT Virtual Dos Machine.
In Windows XP, as in Windows 2000, or Windows 98, there are 16-bit and 32-bit environments (real mode and protected mode respectively).
Windows XP can only operate in 32-bit mode. All 16-bit applications must work within its own theatre of operation, typically, the first MB of physical memory (ram). Conversely, 32-bit applications must function above the first MB memory line. If either of these applications happens to slip into "alien" territory, you get an error message like "something" has encounter an illegal instruction. In other words, the wayward application is trying to slip by the immigration checkpoint.
In your case, updatemgr.exe (I suspect updatemgr.exe is a 32-bit application) has in all likelihood wondered into the 16-bit arena. Hence, NTVDM CPU issues that warning.
Why do you continue to get the message. It's because updatemgr.exe incessantly misbehaves itself on start-up, always trying to load itself into a particular memory address where it is not welcome. Why the persistence? Updatemgr.exe has gone bonkers. It is either corrupted or damaged.
On the other hand, one cannot discount the possibility that NTVDM (NTVDM.EXE) is corrupted or damaged. So your problem lies with either updatemgr.exe or NTVDM.EXE, or both.
There are 2 things you could do.
First, establish who owns updatemgr.exe, Microsoft or some third-party owner. Second, rename updatemgr.exe and see whether the message goes away.
To establish ownership (and the function of updatemgr.exe), do a search for the file.
Click START, select FIND. In the FIND dialog box, type: updatemgr.exe. See the directory in which the file has lodged. In Windows Explorer, get to the file, right-click on it, select PROPERTIES. Who owns it? Is there an indication of its function.
Next, rename the file. Right-click it, select RENAME and rename it to, say, updatemgr.old. RESTART your computer. Do you still get the error message. Not likely.
To clean things up a bit, perhaps it is a good idea for you to replace the current NTVDM.EXE with a new copy. Find out where NTVDM.EXE is. Then, click START, select RUN. Type in the RUN dialog box SFC to run the System File Checker. Insert your OS CD, follow the prompts, extract a copy of NTVDM.EXE and send it to its place of residence. Of course, you should also replace a copy of updatemgr.exe.
That should eliminate your problem for good.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Compaq Presario 5000 PC Desktop Logo
138 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
