Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
F2 & Alarm problem with cloths
When I run the washer empty it does not give me any errors, only when I run it with items like towels.
I have already cleared the trap, tub drain and pump.
Anyone have any ideas.
  • Mike Feb 20, 2009
    I tried running a load with HE soap and it still gave me the same error. Once I removed the load and told it to spin & drain, it completed with no errors.
    Sergeant:
  • 250 Answers
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F2 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. F2 & Alarm problem with cloths - globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check the electrical connections at the pump and make sure the pump is running. F2 & Alarm problem with cloths - globul1a.gif"http://i.fixya.net/uploads/images/globul1a.gif" alt="globul1a.gif" class="h_mi" /> Check the drain pumpF2 & Alarm problem with cloths - globul1a.gifforeign objects. globul1a.gif If the above does not correct the problem, replace the pump.
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display. * Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F2 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F2 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F9 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F2 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Posted on Feb 15, 2009
What does f2 messege mean?
F2 This error code indicates that drain times are longer than expected.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Oct 08, 2012 | Maytag MHN30PDAWW High-Efficiency...
F2 error code won't drain
The problem is with rotor assembly of the drawer that is causing the F2 error. Turn power off. Empty water using a small container and towel to dry base.
Remove the washer arm and drain filter sump cover. Twist the rotor at the base out from the socket gently but firmly.
Clean the cavity and check the rotor for damage. Put everthing back in and turn power on.If F2 does not go away then replace rotor.
Aug 21, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
What does it mean when it gives you a f2 on error on your washer
F2 is a flooded base and that you can drain it by tilting the dishwasher back 45 degrees (have towels handy). If it continues, likely to be a leak that needs repair.
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 does not drain after first load.
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open. After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the large item filter out of the drain pump assembly as shown in the second image below. You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Feb 23, 2010 | Kenmore HE2 Plus Front Load Washer
Front Load Washing Machine
Yes, probably a slow drain. F2 can indicate a long drain time. Press pause/cancel twice to clear. Disconnect the power to your washer, and clean the strainer. It is located behind the kick panel, between the drum and the pump. Remove the debris and clean. Caution, you will get water! Have something ready to catch it. Reassemble. Put the washer on the hottest setting available and run an empty, extended load with bleach. It may be necessary to do it more than once, but perservere, you'll get it. Run a last, empty load with just plain water, to flush the remainder out. This should do it.
Best regards, --W/D--. Please feel free to rate this solution!
Jul 26, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer won't drain or spin, get F2 error
Hello hernandez160,
The "F2" error is referring to excessive drain time. Unplug machine before working on it. Remove screws on bottom of lower panel and remove panel. The drain pump is behind the panel, It has a large round door on it, turn counter clock wise by hand to access pump clean out. Have lots of towels ready. Remove anything from pump (usually kids socks or small clothing articles). If nothing in pump clean out remove suction boot from drain pump and check there. If nothing there blow through the drain hose from the pump side to check if anything is stuck in the hose. If that's clear check the electrical connection on the pump, make sure nothing is loose or broken at the connection. If all this checks out good and it still wont work you probably have a bad pump and it will need to be replaced. If you do find something was blocked or clogged due to small clothing articles I would recommend a garment/lingerie bag to keep all the small stuff together during the wash cycle. Hope this helps to fix your problem. Please remember to rate this and every solution you get.
Thanks,
edgin96
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Kenmore elite he 3 front load washer
Have you checked the drain pump reservoir? This is a common point where debris collects and causes slow drain and no drain issues with this washer. The following link provides guidance on how to check:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you have checked the drain pump, have you checked ALL the drain lines? The drain line that leads from the bottom of the wash tub to the inlet side of the wash pump is another common area where items get stuck. Its also an area that most consumers forget to check. I have found small articles of clothing such as wash cloths, underwear and socks, stuck in this hose causing slow drain problems. NOTE: It is recommended that you use garment bags for small items).
If you verify everything and still have the "F02" Long Drain error, it is recommended by the manufacturer that you replace the drain pump. If anything has been in the drain pump for any length of time, it could potentially damage the pump impeller and/or motor. The pump may be running, but it may not be pumping.
I hope you find this information helpful. Let me know if I can assist you further.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
148 people viewed this question
Sal De
fordexpert
Robert Rankin
