Question about Philips DVDR3320 DVD Recorder/VCR
SWtart up unit
I have a Philips unit DVDr3320v linked to a TV. When I switch on the DVD/VCR the title screen comes on the TV screen but will NOT fire up the rotating disk icon and set the unit for use. Can anybody help?
  • derekrhaywar Feb 16, 2009
    Have tried other disks and with no disk, problem still occurs.
  • 6,487 Answers
Try to play a different disc to check if this is a problem with the disc that you have ...
Posted on Feb 16, 2009
How to remove jammed tape from philips dvdr3320v combi
Remove the top lid from your machine, next see if you can carefully remove the tape "without pulling" if it won't come out, cut the tape with scissors and make sure all tape particles are removed, sometimes by removing the defective tape the vcr will function. Now if it won't work after that point you probably have a mechanical issue which will require a repair shop.
Dec 22, 2010 | Philips DVDR3320 DVD Recorder/VCR
I only have cable tv. when i connect my magna avox
This unit does not have a tuner to receive TV broadcasting. If you have the owners manual on page 26 it explains this. If you do not have the manual here is a link to one.
http://www.magnavox.com/pdf/mn/DV220MW9_mn.pdf
Sep 05, 2009 | Philips Televison & Video
Philps DVD Recorder/VCR
Barbara,From your description of multiple problems there is, more than likely, a circuitry problem that is causing the unit to shut down. Unfortunately, this is not an easy fix and will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the unit.
I just checked eBay and there is an identical model (Item number:300342819479) priced at a "Buy It Now" price of $44.00. So there is your answer. It would cost less to buy a replacement than to repair your unit. Like I said: "welcome to the world of disposable electronics"!!
Aug 20, 2009 | Televison & Video
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Philips tv with built dvd , dvd keeps coming on,
Initially, try to clean the lens/laser with the use of a CD disc cleaner. Shouold that not be sufficient, pls post back the model number of the TV /DVD unit.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Timing
Follow the basic recording instructions from p.32 of your user manual, and add this step:
Press RECORD (z) repeatedly to select the
recording time length. Recording starts after the
first press.
DVD: Each subsequent press increases the
recording time by 10 minutes.
Here is a link to the manual:
http://www.p4c.philips.com/files/d/dvdr3320v_37/dvdr3320v_37_dfu_aen.pdf
-Tha Mp3 Doctor
Sep 04, 2008 | Philips DVDR3320 DVD Recorder/VCR
Playing recorded DVDs on PC or other DVD player
Recordings from your DVD recorder should play on other DVD players as long as you finalize the recording on your recorder.
A PC should recognise an un-finalized, but only in a DVD writer drive.
There is a firmware upgrade available for this model. Follow this link and select your particular country version DVDR3320/XX
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dvdr3320v||page=1||show=50&xsl=search_result.xsl
Select Software & Drivers and click on the link to the zip file.
Follow the on-screen instructions.
Mar 02, 2008 | Philips DVDR3320 DVD Recorder/VCR
PSU Problem
This is known as toast and is not worth repairing.
Dec 22, 2007 | Televison & Video
Philips DVD 750 VR
It may havee a problem with the button you need to press to switch from VCR to DVD, from what i understand and have seen this switch over is not automatic. On your remote you should have a control to switch from VCR to DVD. In addition on your unit there should be a button to switch from VCR to DVD. Try this and let me know how it turns out, if you are still having trouble we can setup a troubleshooting session.
Sep 10, 2007 | Philips DVP642 DVD Player
Philips DVDR3320 DVD Recorder/VCR Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
