Question about Sharp LC-45GD5U 45 in. LCD Television
No Picture Purchased in January 2006 Picture stopped appearing. Sound is fine. Cable box is fine. DVD is working. TV backlighting is working. No image Has something burned out?
  • rexfordh Feb 16, 2009
    Guru: thank you!! the reset button worked. I was not even aware there was a reset button. If I had known it, I would not have known to use it for this problem.
  • Anonymous Mar 29, 2014
    Faint image but no backlight or sound
    President:
  • 1,077 Answers
If your TV is a SHARP LC-45GD5U,
Try using the reset buttons on the back of the TV. It should be below your digital audio output port.
If that doesn't work, ( this is only a guess) the power supply for the LCD screen may have burned out.
Posted on Feb 16, 2009
  • Mike Nov 28, 2012
    Awesome, that fixed my problem too, no picture, sound was audible, thought I might have to buy a new TV..FixYa to the rescue!
I was using the satellite remote to find another show when the TV picture went black, then a minute or two later, the audio stopped. The satellite signal is still there (It is being received by another...
Hello.
First you have to figure out location of problem. That means is it inside of your new TV or outside of it?
Best way is to connect DVD player with new set of wires to different input and make sure it is working fine picture and sound wise. If OK - connect it to the same input that you are using with satellite box right now. If it works just fine - problem is outside of TV and originated in box or connection cable.
If DVD player does not work on any input - you have to call your TV manufacturer and schedule an appointment for repair tech. It is should be free of charge because you have 1-year warranty.
Or you can simply return/exchange your TV at the store you purchased it from (depend on store policy).
Regards.
Russ.
Dec 01, 2010 | Televison & Video
No Picture
I doubt that your component has burned out. You may be looking at a repair issue here even though your unit is only 3 years old IF: you have tried connecting using different inputs, OR if you cannot bring up your sharp menu, or you list of inputs. If you cannot do those following things, you have a SERVICE issue on your hands and unless you purchased and extended warranty with sharp, its useless calling them. They will just tell you tough luck, and refer you to one of their authorized service centers. good luck
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV does not always recognize the DVD player
that's a firmware problem where your tv's firmware does not handshake with your dvd's firmware. This could be from your dvd's software being to old for your tv to understand it. HDMI (TDMS Technology) still has Alot of catching up too do with 3rd generation tv's. Alot of HDMI devices still have the first gen software loaded into them. So a tv after 2005 won't work with HDMI from 2003 (1st gen). Most tv's made after 2007 have software that's "backward compatible" so they will work with first gen HDMI.
How does your tv perform outside this problem???
Feb 10, 2009 | Samsung PN50A550 50 in. Plasma TV
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
No picture, but can hear sound
hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Feb 11, 2008 | Cyberhome CH-DVD 300 DVD Player
Sharp LC-45GD5U 45 in. LCD Television Logo
164 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
