Question about RCA HD50LPW175 50" HDTV
My RCA 50'' DLP Rear Projection TV will not turn on
When we try to power up our 50'' RCA DLP TV the blue lights on the bottom right corner of the TV flash and then go off and the TV does not fire up.
I ordered and changed the bulb and TV will still not start up.
I checked the power supply by bringing up a 42'' RCA DLP TV from our basement and it works perfectly.
I am not sure what to do now.
  • Anonymous Mar 01, 2009
    My 50" dlp at first would shut itself off then back on while watching it,and sometime i would be sound asleep and then BAM.. it would be up and running on its own and then i would have to get up and turn it off. then one night kicked back watching it and it went off, but when it went to come back on it lit up on the controls flashed five times and repeats. Thats all.
  • 257 Answers
Hi, This could be several things as the power goes everywhere. Long distance troubleshooting so hang in there. First try a cold reboot by unplugging and replugging after 30 minutes. If nothing check P1 on the light engine for the following voltages: pin 2 5vdc, pin 3 3.3vdc, pin 9 3.3vdc, pin 12 12vdc. If any of these are not good it is the formatter board. If all are good, does the color wheel spin at all. If this is OK then check J4 on the light engine, the ballast enable line should be 0 vdc in stby, .5 vdc at turn on, and 2.5 to 3.25 vdc in run. If good, is the light engine trying to fire the lamp? If not, inspect the J4 connector and the lamp power supply, If they look OK then the lamp ballast is probably bad. This will give you something to do for now, Good Luck!
Posted on Feb 15, 2009
I have a rca 50" rear projection tv it had a
I will need the model number of your set to see if its a CRT projection or DLP projection. DLP would be a color wheel most likley.
Mar 17, 2011 | RCA Televison & Video
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
Good morning, i have a 50'' rca hdtv rear projection.../ and when i turn it ''on'' there is no sound and no picture..but the blue light comes on and then blinks 4 times and the 5th time it stays on then...
You might have a bad lamp. RCA DLP projection That is the most comon problem with them. CRT rear projection, Red,Green,and Blue tubes.If it is the silver one w/the black speaker grill. Chass # _ _ _222 ?
Has 222 in the number.Can be several problems. Many things go wrong in those. Horz. Output,Flyback,And bad soldering are the most common problems w/those. Recomend staying away from RCA. Not the same company they once were.
Jan 01, 2010 | Sanyo DP50747 50 in. Plasma TV
50 inch rca dlp
You need a new lamp... part number 260962 (RCA) or Philips 260962RL.
JOE
Jun 20, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Samsung 50in
That is a mirrior adjustment problem, it is pretty complex to fix yourself and you can really mess up the T.V. if you don't know what you are doing. I suggest a T.V. repair man that specializes in DLP TV's.
Dec 30, 2007 | Samsung HLN5065W 50" Rear Projection...
No picture
Sounds like it could be the entire light engine.  The part is available on the Internet, but it runs $700 - $1200 without the lamp (although it sounds like you could use your existing lamp without a problem). These parts, however, are notoriously hard to find and may be backordered for months.
May not be worth the cost, but that's up to you.
Oct 25, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Dark spot in bottom right corner of screen
Is this a DLP or a conventional 3 tube projection tv?
Sep 15, 2007 | Hitachi 50V710 50" Rear Projection...
RCA HD50LPW175 50" HDTV Logo
955 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
