Question about IBM ThinkPad A21m 2628 Notebook
Battery will not charge.
I cannot find continuity between the positive side of the D C plug and the positive battery connection. It is as though the connection is broke.
2 Suggested Answers
  • 38 Answers
SOURCE: Battery will not charge.
Your not going to get continuity when you measure through a battery charging circuit. Check the power supply.
Posted on Mar 25, 2009
96 fordexplorer i put new battery and altenater but still not charging
On the alternator there is a heavy red cable (wire) going to the battery. The battery gets charged though that wire. There is a fuse in that wire between the alt and batt. That fuse is called a fusible link. Check the voltage on that wire at the alternator. You should have baytery voltage there. If you have no voltage, the fusible link is burned out.
Jan 15, 2015 | Cars & Trucks
Sony FD mavica will not run on charged battery, will run plugged in to charger
You either have:
1) a false positive on your battery, meaning that they aren't really charged even though they say they are (especially common the older a battery gets), or
2) the battery connection is faulty/dirty, while the AC adapter is fine. If the AC adapter uses the battery port, then the battery is your problem.
Nov 09, 2012 | Cameras
How to charge battery
Hello: Make sure key is off, open hood, on passenger side near inside of of fender you will see the positive and negative connections that go to the battery. (the battery is under the back seat on the passenger side, you might check connections to the battery for excessive corrossion) When checking for corrosion, remove cables from battery, the negative (black) first then the positive (red) Make sure key is off. If no corrosion re-connect battery. Hook up charger under the hood (black lead to black ground point and red to red positive point. then follow directions on your charger. Remember ignition key off.
Jan 24, 2011 | 2000 Buick LeSabre
How do you change a battery in a 1999 chevy venture van
Assuming you have a battery charger. Do not plug charger in until after it is connected.
1. Open hood & locate battery.
2. Identify the positive terminal of the battery (usyally has a red cover or red marking.
The battery has side terminals (not posts like nonGM batteries)
4. Connect the + red clamp the the positive terminal wiggle it a little to get good connection.
5. Connect the negative black clamp to the engine block, a handy bracket on engine or the negative terminal on the battery. DO NOT CONNECT TO ALTERNATOR
6. Be sure connections are secure.
7. Plug in charger it should show charging. Leave it over night
8. Before disconnecting charger disconnect power to the charger.
THE FUMES OF A BATTERY ARE EXPLOSIVE DO NOT USE FLAMES NEAR BATTERY
DO NOT ALLOW SPARKS NEAR BATTERY!
Dec 08, 2010 | 1999 Chevrolet Venture
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
TOSHIBA U400 running VISTA; When I am on battery and get low i plug in so i can continue working but even though the lighted icons on the laptop show it is plugged in and charging and the toolbar icons...
Yes it is, seems there is some problem with the power state detection and changing of the load mode. Might by a physical problem, so I am not sure you can fix it.
At least check your power plan details and see if there is any error with the ACPI devices in the device manager.
In general, if you use the laptop when plugged, you should take out the battery to maximize the battery life (prevents useless load cycles).
Also configure Windows to optimize battery usage.
Apr 24, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
Battery won't charge ...
Means that your battery is gone. Please change. The camera works on direct power, henca the battery is gone.
Aug 03, 2009 | Canon DC210 DVD Camcorder
My T-Mobile MDA won't turn on or take a charge, battery was low
I had the same problem, but got the idea to "jump start" the battery from Googling the problem. At night, I had turned off my MDA to charge the battery and then in the morning, couldn't revive it. I removed the battery from my MDA, and determined which battery terminal was positive (far end of one side) and negative (far end of the other side) by using a multi-meter. BTW: Battery was still @ 3.5V (okay…battery was still alive, if just barely). Then, I found a 5V DC charger (5W Max output = ~1A) from my bluetooth headset. I used one wire (CAT5E) and connected it to the negative side of the adapter (outer sleeve - again, verified by multi-meter) and another wire to connect to the positive tip of the adapter. I had to strip about 1/2-inch of the insulation off of the wire on the DC adapter side, and about 1/8-inch of the wire on the battery side. Plugged in the 5V DC charger and then I touched the negative wire to the negative battery terminal and held it there, while I touched the positive wire to the positive battery terminal for about 30-45 seconds. Put the battery back in the MDA, started it up, and now it's charging on the regular MDA AC Charger that came with the phone. Problem solved.
Apr 07, 2009 | T-Mobile MDA
Feb 15, 2009 | IBM ThinkPad T20 2647 Notebook
I lost the instructions and it continually says low battery
I had the same problem and discovered from the instructions it will only charge the battery if in the "off" position on the side ie it is not charging if it is plugged in to a power source and being used.
Jan 24, 2009 | Philips PET702 Portable DVD Player
IBM ThinkPad A21m 2628 Notebook Logo
96 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
