Question about Garden
Crafsman Eager 1 6.75 HP lawnmower wont start
A friend gave me an old craftsman lawnmower-Craftsman Eager 1 6.75 hp and I do not have the manual for it. Is there anyone who can help me with how to start this mower? I pull the cord, hold down the speed cable and nothing happens-Is there an on/off switch here?
Please e-mail me at b.dussich@comcast.net -Thanks!
  • 2 more comments
  • b_dussich Feb 16, 2009
    Mrfixit-jerr-
    Your answer was EXACTLY on the mark!! I actually did the things you mentioned and it started right up.One thing I learned as a kid working on mpowsers that won't start was to remove the sparkplug clean it, sand paper (slightly) the electrodes, and put a SMALL tinblesize amount of gasoline into the cylinder. Once I did that, after putting in a new airfilter(totally clogged up!) and used a new plug, it started right up.! I will definitely use this site again!! THANKS! Bob
    Mrfixit-jerr-
  • Anonymous Apr 27, 2009
    **** u mr fixxit
  • Radiorara May 09, 2009
    My Eager 1 Craftsman Techusma 6.75hp engine 22" mower will not start. Model year 2001 I think. I have changed the oil, spark plug, air filter, cleaned the carb, changed the blade and primed the thing plenty and even used carb cleaner but this bastard still wont turn over. I have the same problem with another craftsman 21" mulching mower with a B&S engine. THe B&S one at least sputters and makes an attempt but will not get up to speed. I gather it is probably the carb on both of these junk piles. The B&S one is only 2 years old.
I have an Eager 1, as well and when I try to pull the cord it does not turn at all. It's stuck. I hit a tree root and since then I have had problems with it. I have 2 mowers so it was not used last year at all. Gas was drained and it was stored in a shed. Anyway, I know nothng about mowers other than spark plugs, gas, oil, sharp blades and filters. Is the motor seized? Thanks
Posted on Apr 05, 2010
  • Daryl Albertson Aug 22, 2013
    all you have to do is take out the spark plug........then give it a few pull this will release the vacum lock from the engine
I've got a Sears Eagle-1 6.75hp mower that wont start. It will start up if I pump the primer but it will not stay running. I've do need to change the filter, it was dirty and had caked on dirt in it. I cleaned it and it is flowing air. I tried starting the lawn mower with the filter of and it does the same thing. Could I have dirt in the fuel line to the carb? If so, how do I get it out?
Thanks,
Posted on Apr 01, 2011
  • 3 more comments
  • Jonathan Nitkowski
    Jonathan Nitkowski Aug 04, 2012
    I've got the same issue. I even pulled off the carb and cleaned all of the jets w/ carb cleaner. Does the same thing...starts fine but won't stay running. Help anyone?
    you will need to bye a rebuild kit your difram is bd
    Add a Commentbad
    bad
  • curiousgoods
    curiousgoods Dec 05, 2014
    Take carb off.Sray it with carb claner.f it has a bowl@float.Thats were yiour problem just might be.Dirt.
How do you replace the large belt on a Craftsman 944.609160, 16 hp, 44" cut
I coulnd not find the owners manual online, however if you can take a pic of the top of the deck I could probably tell you how to string the belt
Aug 29, 2014 | Craftsman Garden
Where are the kill switches located on my Craftsman 917.256711?
most lawnmowers have one for the reverse and under the seat some have them on the brake pedal to start it if it breaks it wont start
Aug 15, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawnmower wont stay running
Michael it sounds like there may be a blokage on you air filter. Check it and clean it then make sure there is not too much oil in the mower.
Jul 18, 2013 | Garden
Would like to find manual on craftsman eager-1 model 389591
Hi and welcome to FixYa, I am Kelly If I got the model correct this is a 6.75 Hp rear discharge mower.
Go to this page:
http://www.hammerwall.com/Manuals/Craftsman/Description/917.389591/Craftsman%206.75%20HP%2021%20in.%20Rear%20Discharge%20Rotary%20Lawn%20Mower/L0103219 and then after you see the front page of the reduced size manual cocl on "Manual Location" to begin the download of the manual.
or
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0103219.pdf Direct download.
Thanks for choosing FixYa,
Kelly
Aug 07, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
My Craftsman 6.25 HP lawnmower won't start. It has fuel, have checked and cleaned and gaped plug. It does not seem to be getting any spark. Unit is 2 years old, in good shape. Any idea what to do next or...
Mine sometimes has no fire and I find it is usually the cable operated kill switch is too slack and not releasing the very poorly and cheaply designed kill switch.
Jan 30, 2010 | Craftsman Garden
Craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
Aug 31, 2009 | Craftsman Garden
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Garden Logo
4,853 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
