Question about Whirlpool LSR6332K Top Load Washer
The slow weak function of the augar
The augar moves at a snalis pace and a very short distance back and forth. When I apply pressure to the top of the augar while running, it works correctly.
What do you recommend I do to fix the problem?
    President:
  • Whirlpool Master
  • 2,651 Answers
The reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Posted on Feb 15, 2009
Clutch fork on 2002 dodge neon not moving freely back and forth. Is it a hydrolic pressure issue or is the throw out bearing bad. I just replaced the clutch and throw out bearing
Probably a hydraulic problem.
The clutch fork would normally move the usual distance whether the release bearing is bad or not.
Sep 08, 2017 | Dodge Cars & Trucks
How to free a steering pivot on an evinrude vro 90hp outboard?
Judy, carefully apply heat where you feel it is seized, have assistant try to turn wheel back and forth, when starting to move apply a lubricant at seized point and work wheel back and forth until freed up. ( Careful lubricants can be flammable)
Mar 02, 2016 | Boating
Are there smaller, portable, air casters?
Yes. However they might not be your best solution. Portable air casters usually work best for very short distances and infrequent moves. This means that if you need more frequent moves or travelling longer distances, you will need continuous compressed air supply (high pressure nitrogen bottles), which would make the whole cost more than it's worth.
Dec 30, 2013 | Air Tools & Compressors
My 1992 camry keep cutting off after i drive short distance
I would run a check first on the fuel pressure. Possibly either the fuel pressure regulator or the fuel pump is faulty. It has enough fuel to move off, but not to get up to any speed.
Nov 06, 2013 | 1992 Toyota Camry V6
Car runs perfect then starts missing real bad then stalls
Not unusual for fuel pumps to begin to fail once they are heated up from running. First thing in the morning pump is cool, then as you drive, it heats up and begins to lose pressure. After sitting a 1/2hr-1hr, it may start again and run fine for a short time and start to act up again. Had similar problem and found good fuel pressure when tank and pump cool, but lost pressure once vehicle driven a distance and pump heated up. The hotter the weather, the shorter the distance I could drive. If you can somehow set it up to have fuel pressure checked when it starts to act up, that would certainly help confirm if fuel pressure is the culprit.
Jan 10, 2013 | 1996 Dodge Stratus
Bobbin thread knots up - needle only moves very short distance and feels like it is hitting something. I changed needle but it will only go down so far and something stops it.
Your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 29, 2010 | Singer Sewing Machines
Tire pressure in manual is 21psi, front and 22psi for rear. Do I need to increase this for on road riding? Pressure seems low for on road riding?
Here's my take on tire pressures and when they need adjusted, I wrote this a while back for someone with a Honda African Twin, so this should help:
Manufacturer's recommendation – Short distance city riding below 100kph. Light off-road use ie. Small rocks, gravel. If the weather/road conditions vary a lot.
30% above recommended pressure – High speed road use. Long distances in warm weather on good quality roads. Go 40% if the conditions are the same but the bike is fully loaded with carriers.
15% below recommended pressure – Short distance riding in cold winter temps. Short distance on wet roads. Off-road, average gravel/rocks and some wet mud.
40% below recommended – Slow off-road riding in very loose dirt, sand, with lots of rocks. Tires will heat up quickly if the pace is picked up which will loose grip and cause accelerated wear.
60% below recommended – Very slow, loose dirt, deep sand (dunes). If tires slip on the rims you need to increase pressure.
My mantra is all about keeping a close eye on tire pressures and adjusting them to suit the conditions rather than keeping strictly at the manufacturer's settings. Starting out my riding career on a BMX, tire pressures can be the difference from landing a perfect jump and falling on your face. Therefore, with a motor attached, it is even more important to get it right – personally I think the 'feel and grip' is more important than the pressure number – regardless if that causes tire wear.
Hope this helps and you vote for me :)
Jul 01, 2010 | 1995 kawasaki KLE 500
Oil gauge on tahoo moves back and forth
Is it the factory oil guage? Is it an electronic or mechanical guage? if it is mechanical that means you actually have a small diameter tube from the engine to the dash area, which may have a kink or bend in it. If it is electronic then your dealing with a wire which can have a slight short in it or a bad connection. REMEMBER!!!!!!!!!
An oil guage that works properly will have up and down readings. When the RPM's increase, so should the oil pressure guage. when you are not running the engine( idleing) the guage will read lower and sometimes bounce back and forth around 5 PSI. sometimes more depending on the grade of oil, how hot the engine is and how old is the oil.
Sep 19, 2009 | Innova te Motorsports G2 Oil Pressure...
Key wont turn
Press brake pedal and move the steering wheel back and forth while applying pressure to key to see if it activates!! you need to unlock the key basically...
Sep 18, 2008 | 2002 Chevrolet Malibu
PS2 not reading disks
Your lazer lense has bit the dust. Depending on your model type the first gen systems lazers are very easy to replace. The later versions sony made it harder to replace. You can find out what model you have by looking at the back of your PS2 then you can either call sony or go to there website and find out what generation PS2 you have. Then go from there. Hope this helps
May 08, 2008 | Sony PlayStation 2 (PS2) Console
Whirlpool LSR6332K Top Load Washer Logo
135 people viewed this question
Dan Webster
Dan Webster
Sal De
