Question about Gateway 816GM PC Desktop
We've had a Gateway 816GM desktop for about 3-years and except for the usual PC problems it's been fairly reliable. However, in the last few days it started locking up, no video, then it starting hanging and finally it will now not boot up at all. The HD light on the front doesn't even light up. A friend did a quick look at it and suggested the motherboard was gone. I'm assuming if the hard drive was bad the computer would at least boot up, but I don't even get the start up screen or any video. I've checked our monitor on my laptop and it's fine. If it is the m/b, what is best....a new m/b or a new desktop (hopefully not the latter)? Finally, assuming the hard drive is good and we replace the m/b, are all my files and pictures on the hard drive still saved? Bill in Florida
    President:
  • Gateway Master
  • 1,314 Answers
Bill,
If the hard drive is still good, your files are safe. Replacing the motherboard may mean you will need to reinstall the operating system so you will have to get the files off before you do that.
Now, even though it could be the motherboard, it could be any number of things. If I read your post correctly, nothing happens at all now? You push the power button and nothing? This to me sounds like the power supply. These go out quite frequently and a failing power supply can cause it to lock up. When the power supply fails completely, then you don't get anything. These are relatively inexpensive.
If a new power supply does not solve your issue, then start by removing all internal cards, floppy drives, cd drives, hard drives from the computer. Actually, you can do this first to make sure it still doesn't do anything before replacing the power supply. Then try and turn it on only with memory, cpu, cpu fan, and the onboard video (or video card if it doesn't have an onboard video port). If it does work, then you can add each item back one by one until you find the culprit. However, in my experience as a PC tech, this is almost always the power supply. Probably something like 95 % power supply, 4 % motherboard, and 1 % other. Good luck and if you need any further assistance, let me know. Also, I would appreciate it if you could give this solution a rating of fixya. Thanks! :c)
Posted on Feb 15, 2009
  • Gateway Master
  • 19,396 Answers
If the hard drive was bad the computerwon't boot at all, same if motherboard hard drive was faulty.
In your case the problem is not hard drive or motherboard, but a system problem.
You need to reinstall Windows with a setup cd or a recovery cd.
    Sergeant:
    Champion:
  • 237 Answers
Well it sounds like there are 2 different issues one is the power supply and the other being the motherboard. When you try to boot do you hear any fans going? Also look on the mother board itself and some of them have a led light do you see one and is it lit?. And if you replace the motherboard your files will be just fine.
No sound on speakers except on itunes
I cannot find drivers on the Gateway Support site, which usually means the machine is no longer supported, which also usually means the Operating System is no longer supported. If this machine is running XP, or earlier, beware. It is no longer supported, and hackers will be looking for these machines to infect. I recommend you get a newer machine, or don't try to get on the Internet with this one.
Jun 24, 2014 | Gateway 830GM PC Desktop
I have a Gateway GT5654 desktop that won't stop shutting down. I bought the computer brand new about 3 years ago, and I've never had any problems until now (I've even been running Norton 360...
it is possible that one of the three are going out on the computer, motherboard, harddrive, power supply, only a computer tech could tell which one.
Sep 21, 2011 | Gateway GT5654 Desktop PC
I have broken headphones and michrophone jacks on the front of the computer. Where can I find the component part # and where can I get a replacement?
Please the following link and click on show part number under Audio Jack, you will see the following image:
If you follow this link you will have few options to order your part.
Please let me know if you need additional information.
Regards
Mar 12, 2011 | Gateway 816GM PC Desktop
My computer keeps freezing when I run video
A possible RAM issue; having problem you applications
Mar 14, 2010 | Gateway 816GM PC Desktop
Have a 815 GM computer that when I push the power switch, the power light comes on only when I keep it pressed in, but the compter won't power up. It may be a power supply or a fuse problem? Does this...
It is a power supply problem. The only fuses are in the power supply. Do not open your power supply they can cause a shock. A new power supply is only about $20
Aug 15, 2009 | Gateway 816GM PC Desktop
GT4022 Gateway FIC KTBC51G Motherboard died
How did you determine that the MB was dead? Do you know how to use a post card and do you have one? How old is your computer and is it worth it to replace the MB? It is usually fairly easy to find a replacement MB on Ebay. Although, today desktops are so inexpensive that you may want to try that route. If you do replace the MB make sure that your power supply is adequate. We build systems every day and we never use less than 450W. If you do decide to replace the MB email me if you run into any problems and I'll see if I can assist you.
Jul 30, 2009 | Gateway GT4022 PC Desktop
I've got a gateway 816gm coputer and had a virus and downloaded a program to get rid of it, now I've lost something on my hard drive in the NTFS part.My desktop will not load internet explorer or some...
In your situation, please make a list of all your apps that you lost. For the internet explorer, if you have another pc you can get to the internet on, I recommend downloading IE7. Then you will need to go to add/remove programs, windows components tab, uninstall the version of IE that you have. Next take the copy of IE7 that you downloaded from MS, and install.
It will require some work to re-install all of your programs... I would advise you to contact Gateway and see if you can get a disk from them and re-install your OS, If the virus did that much damage you are better of to start with a fresh copy of windows.
Mar 14, 2009 | Gateway 816GM PC Desktop
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
No power except fan
It's your CPU. It sounds like you didn't apply the thermal liquid between your CPU and fan.
Mar 29, 2008 | Gateway GT4022 PC Desktop
Gateway 816GM PC Desktop Logo
243 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
