Question about Zanussi 23 in. ZDT6252 Built-in Dishwasher
Changing heating element.
Is it difficult to change a heating element on a ZDT-6252. One of my customers has been let down by local agent and have asked me (electrician) to see if i can fix it.
You normally access the element from the side , Be careful of sharp edges . meter it before you start spending money it could be a timer fault also !
Maurice
Posted on Feb 23, 2009
My zanussi ZDT 6252 has rinse and hold and intensive lights flashing and is humming
Have you proper water pressure or is the water tap turned on or kinked? If so - fix it and try again.
Dec 13, 2014 | Zanussi Washing Machines
My zanussi built in zdt 5044 is not heating water. How do you access heating element etc?
Element should be underneath the unit. You will need to disconnect the unit, to work on it.
Oct 24, 2013 | Dishwashers
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
Jul 29, 2010 | DeLonghi BCO120T Programmable Espresso /...
The oven wont turn on,fan works but heat wont come on
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer. Can give further advice if you provide a model number. Good luck!!
Mar 10, 2010 | Fisher and Paykel Ovens
Just moved in and run the dishwasher
Replace the timer.
Most likely it was broken by someone resetting the timer by hand while the unit was energized.
Always open the door(de-energizes the timer) when you want to make an adjustment to the machine while it's running.
Jun 21, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
296 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
