Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
Picture distortion upon startup
Upon startup, my Sony Bravia KDL-46V4100 46in. TV has color distortion and picture fade in the middle and the right hand side of the screen. After 10 or 15 minutes, this goes away and the picture is normal. Any thoughts on the cause of this problem. I have a 3yr warranty so I'm covered if it is something major. Thank you for your time.
  • 1 more comment
  • bobbyc1025 Mar 01, 2009
    i have the same problem but my model # is KDL46S4100
  • sdnorris Mar 04, 2009
    I appear to have a similar problem. Upon turning on the TV I get a distorted picture on the left side of the left-middle side of the screen. Essentially a flickering image with a few horizontal lines through the TV. After several minutes the picture clears. Has anyone had any answers or progress?
  • Anonymous Apr 16, 2009
    This is an obvious defect in this set. I have similar problems.
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
SOURCE: Sony Bravia LCD KDL 46V4100 has distortion with
I have this exact same problem on my same model TV. It started just before Christmas. Have you been able to find any resolution?
Posted on Jan 07, 2011
SOURCE: I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Posted on Jul 28, 2011
What has gone wrong with the image on my tv?
The T con board is responsible for what you see and is responsible for bad, distorted images.
Oct 20, 2015 | Sony BRAVIA KDL-40BX420 40" LCD TV
Distorted Colors on Sony Bravia KDL-40Z4100
T'Con board fault. For most Sony sets; T'Con is an integral part of the panel. It will be best to contact the authorized service center for Sony in this case. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 08, 2015 | Sony Bravia KDL-40Z4100 40 in. LCD TV
Bravia problems sony tv
Just visit the site given below. It has screen shots to defective Sony Bravia. Compare it to that of your TVs' and make sure about the fault. In most cases, the fault you described here sill be repairable.
Nov 20, 2013 | Televison & Video
My Sony BRAVIA KDL-40EX400 will not turn on.
IIC bus clock and/or data lines low at power on 06. This is the fault, according to the blinking codes given by Sony LCD TVs. That is, the fault lies within the main digital board. To locate the exact fault point to these type of fault, is actually a skilled one. If you wish to get more details to this fault, check the link sited here.http://electronicshelponline.blogspot.com/ It has details about these blinking codes. Before proceed, once again count and make confirm the number of blinks occur at one time switch ON. Pull up older posts by this link at its left side bar.
Jun 06, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
About 3 yrs old. Picture is distorted for about 1/2 hour until tv warms up. Now has horizontal lines going through the picture and stays distorted on the right side of the screen.
This tv problems it is alway the board that call the T-CON decodering board it is dying.This T-CON decodering board sit in the middle at the bottom of the tv LCD screen panel.This T-CON decodering board decodes all the tv picture dots pixels before it go into the tv LCD screen panel itself.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish T-CON decodering board for the replacement.
May 09, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia kdl 32l4000 - color bars running vertically on screen
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
501 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
