Question about Brother DCP-340CW All-In-One InkJet Printer
Red ink not working on dcp340cw
The red ink does not print at all. I have changed the cartridge but still not working
  • 687 Answers
Try placing a piece of Black Electricians tape over the stepped part of the cartridge make sure it covers the whole of the length this will fool the sensor into thinking that the ink is full. If you just cover a part of it on a near empty cartridge it will save not installed.
This check is done to make sure that the print head doesn't dry out but in my opinion these are set too high and you can waste about 8% of you total ink. If you do this before you install the cartridge you will be able to use all of the ink. Then just replace it with a new taped one...
Posted on Sep 23, 2009
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
Aug 01, 2009 | Epson Stylus Photo R200 InkJet Printer
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
Sep 09, 2017 | HP OfficeJet t65 All-In-One InkJet Printer
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hi I have just inserted a new HP ink cartridge 94 into my HP PSC 2350, as the ink was running low. I was printing photos, which keept printing with a red line throughout the picture. After inserting the...
Try opening the printer properties and cleaning the print heads (should probably be done each time a cartridge is changed), it uses some ink up but should clean the build up from running the previous cartridge dry and hopefully solve your printing problem.
Good luck.
Mar 29, 2008 | Computers & Internet
Red ink not printing
i think your head is bad..
change the head itself..
it will fix you..
thank you.
Feb 15, 2008 | Office Equipment & Supplies
Epsonstyluscx3810printer
try reseating the ink cartridges
if you still get the red ink error light - call EPSON with the date&place of purchase of the said inks
Dec 30, 2007 | Epson Stylus CX3810 All-In-One InkJet...
I had the same problem and I could not print read. I cleaned, put in new ink etc. Here's the kick.... I ran a nozzle check and noticed that the red and the cyan ink cartridges were reversed! I switched them and it worked fine. I don't know it that is your problem but it blew me away... such a stupid mistake, putting the ink in the wrong places.
GJean
www.bacaracka.com
Oct 11, 2007 | Epson Office Equipment & Supplies
Brother DCP-340CW All-In-One InkJet Printer Logo
182 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
