Question about Dell XPS M1530 Notebook
Dell xps,no video output and it sows only white backgrounds
Help me Pls. I have Dell xps laptop,every time I turn ON no display in screen,no out put,it shows only white background..but sometimes it has.thanks!!
  • michael_asun Feb 16, 2009
    kram26,thanks for ur help.. the problem is..if I reformat or reprogram the laptop how?because no display appearing on the screen..is this possible that the video card is the problem?because sometimes the laptop appearing a display,after more or less 10mins it will go back to white screen with stripe colors..thanks,i hope you can help me.
    thanks for your advice...more power.
  • 544 Answers
Hi good day,
on this situation the best way you need to do is to reformat and reprogram the laptop...
Posted on Feb 15, 2009
  • Mark Milan silaran
    Mark Milan silaran Feb 16, 2009
    hi there,
    sometimes the video card is one of the psossible only but in your case maybe it is also hit the mother board that's why even you will turn it on no display is appearing on your screen.
    you will probably ix it by your own only you need a specialist about your proble.
    i prefer to advice you that go to the nearest computer shop for repair..
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
LaptopDell XPS,M1730 powers up but no Display on screen
Hook a spare monitor to the video output usually on the back, if okay! the inverter board just below the screen is the likely problem, or the backlight behind the display is faulty, but if both have the same symptom it is the video graphics card normally built into the motherboard.
Apr 30, 2012 | Dell Xps 17 Laptop Computer (Intel Core i7...
Shadow bands on laptop screen
The backlight behind the display may be starting to fail, hook a spare monitor to the video output usually on the back, if okay! the problem is in the the laptop display, Now if both show the same symptoms, it is the Video Graphics Card normally built into the motherboard.
Apr 01, 2012 | Dell XPS M1530 Laptop
Dell xps laptop lcd screen black
If you have an external monitor, try connecting the laptop to it, then toggle FN+F8 to project display from lalaptop to external monitor.
If the external monitor does not have a display aswell (totally blank) , then its a problem with the video card.
You can also run an LCD Bist test by turning off the system , then while the system is turned off press D + power , If you dont hear a beep but no display at all, then its an LCD problem.
Hope this helps
Thanks
Dennis
Oct 18, 2011 | Dell XPS M1210 Notebook
I just bought a used Dell XPS M170 laptop yesterday and am afraid I got cheated. This morning the monitor went white several times and I had to force shutdowns and then reboot only for the screen to go...
Try connecting an external monitor to the 15 pin VGA (Video Graphics Adapter)and see if you still get a white display. You may have to hold down the function key next to the space bar and depress the key with a picture of a monitor on it to send the video signal to the monitor.
If you still get a white display on external monitor then you have a problem with the laptop's video card.
If the display on the external monitor is fine then you have a problem with the laptop's LCD display panel or I/O cable and they need to be replaced.
Jun 17, 2011 | Dell Inspiron XPS M170 (IXPSM170SAPP) PC...
My dell has issues with the graphics display,at times when i switch it on it just shows a blank greyish black screen,at other times when it works normally it will just start having a background like a tv...
You should try the cheapest solution first. Replace the LCD cable. These should be easy to find on ebay and amazon. My guess is there is a short in the cable.
Nov 29, 2010 | Dell XPS M1330 Notebook
I was watching a video in my Dell XPS M1210 when it suddenly stopped and the screen when blank. I unplugged it and tried to switch on but I still get a blank screen but the power button has lights as well...
The inverter or backlight on the display may have gone out. Connect an external VGA monitor to the laptop. If it works, then the display has a bad inverter or the backlight CCFL lamp went out.
Nov 12, 2010 | Dell XPS M1210 Notebook
The screen will not come on when the computer comes on on my dell xps notebook. The laptop comes on but the screen stays black when turned on.
I had a similar problem with a one year old Dell laptop, and it turned out that the screen was OK on battery power, but when you plugged it in to the AC charger the screen went very dark. It turned out to be the LCD backlight inverter, which I purchased from a fellow in Florida for about $16 and installed by following the instructions at http://www.insidemylaptop.com/remove-replace-lcd-screen-video-cable-inverter-on-dell-laptops/ . Hope this helps you out a bit...
Mar 29, 2010 | Dell Studio XPS 16 Notebook
No Video Output
if the video card is not working , then you'll need to replace the system board.
Feb 16, 2009 | Dell XPS M1710 Notebook
Dell XPS M1530 Notebook Logo
396 people viewed this question
Alun Cox
