Help my daughter has an Elonex webbook after surfing the net last night the screen as gone black! It switches on and off still but thats it, any ideas whats happened???....
  • Della
    Della Feb 15, 2009
    tried removing battery for 10mins as suggested but still remains the same. Cannot test the ram unfortunately.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A fes tests and ideas you may want to consider/explore:
  • power on / boot the laptop;
  • note if it makes the normal sounds/beep when doing so;
  • note if the LEDs lit up as they normally do;
  • after a sufficient time, press the CAPSLOCK and note if the CAPSLOCK indicator would change state;
  • if yes on the above, then most likely, a fault in the inverter (most likely) and/ or a faulty CCF (cold cathode florescent) lamp (likely);
  • you could confirm by connecting an external monitor temporarily;
  • alternately, you can shine a flashlight obliquely against the display screen and determine if there would be some semblance of the desktop albeit very dark;
  • if no, then it would be a hardware fault on either the motherboard, memory, and a host of other possibilities;
  • if so, then your best bet would be to seek the services of a qualified professional not unless you are considering a DIY (do-it-yourself) which would require familiarity with electronic/digital components and circuitry, use of a DVM and possibly a soldering iron.
Good luck and thank you for using FixYa.
Posted on Feb 15, 2009
    Sergeant:
  • 250 Answers
Its a laptop?
just remove the ram by opening the back socket as some screws will be connected on the socket that has to be removed first to remove the lactch under which ram is located.check out the laptop only on power adaptor.remove the battery and keep it out.if the laptop works on adapter withour battery that means the battery is faulty.but if still has the same problem on adapter also.it has to be checked at a local repair center.as they will have all the required parts in spare to replace it and check out whats the faulty in your laptop.that has to be replaced.
    Sergeant:
  • 326 Answers
Remove all the wires connected at the back of the cpu/tower.and also remove all the wires from the mother board connected.then remove all the cards connected on the motherboard and then clean if any dust on the board.also remove the RAM  and clean the golden metal lines on the ram with school used pencil rubber.then reinsert every thing back and check out.if still the same p[roblem.replace the cmos battery and check out its just cost negligible to replace the cmos battery.less then a $1.it should work after that.
  • 13,433 Answers
Do you still have warranty on the laptop? They should replace it or repair it.
if you don't have warranty you could take the laptop apart and remove the ram.
start up without ram
then plug in one of the rams and try staring up again.
  • 19,396 Answers
Truy removing battery and unplugging power for ten minutes first.
  • Ginko
    Ginko Feb 15, 2009
    Try first removing the batttery and unplugging power cord for ten minutes first.
    This is called hard reset and can sort out problems related with settings, RAM and electrostatic charges.
    If that does not work the unit must be taking apart and tested.
    You can start by testing RAM if you have two ram sticks. Just remove one of them and see if the computer boots up with only one RAM.
  • Ginko
    Ginko Feb 15, 2009
    If removing battery did not help , then the unit is faulty and must be disassembled and tested by a technician.
    Test the unit with no battery and only ac adapter.
    If still no luck find a local repair shop and have it fixed.
Factory settings
Check keyboard cable mouse cables rear of base station.pull them out and push them fully home restart in safe mode by tapping f8 key until you reach readable screen then opt for normal last good configuration .this should work if all is well with operating system.
May 18, 2013 | Dell Inspiron 531s Desktop Computer
My daughter was working on her laptop last night and she said it wasnt working right so she shut it off and when she turned it back on the screen was black - I tried the f2 key last night trying to get it...
CPU more than likely went bad because of overheat. Its not worth fixing unless you KNOW you can do it yourself Laptops are a nightmare to work on
Just a suggestion but laptops are for people who MUST carry their PCs around. The do not have a long lifespan. Desktops are much more durable
Oct 13, 2010 | Computers & Internet
Why is my screen pitch black when I turn on my compyer
Hi Hi,
I guess my laptop just got infected with some trojan viruses and the screen is now all pitch black. what can I do to solve this problem? Please help! thanks in advance
I can only open up the task manager by clicking cotrol, alternate and delete and manges to surf the net somehow, other than this, I can't do anything as my screen is unable to load.
I have tried installing 30-day trial version of AVG anti virus but it detected my exrpired McAfee and said conflict of software. So, I can't install a free trial antivirus online. I have Norton bought recently but just didn't manage to get around installing it.
In Real Trouble and need of help,
Jenn
Sep 29, 2010 | Computers & Internet
Gateway 610 (Elonex Exentia in UK)
Check that the video cable is securely plugged into the computer and monitor.
Dec 16, 2009 | Computers & Internet
Pc went off last night turned on this morning but no luck help
tuned on my dell had a black screenit comes on the either net flashes but you dont hear hard drive run and i have a black screenbut moniter is good i checked it
Oct 09, 2009 | Computers & Internet
Black Screen on Startup.
Did you try " Last known good configuration at start up. If after boot you press the F8 key where you said you went into safe mode, did you try to load the good known config. It sounds like you have a corrupted registry.
Jul 14, 2009 | Acer Computers & Internet
Cannot seem to get msn
http://amsn.sourceforge.net
they have an open source (free) msn clone that will work in linux
Robert
Jan 02, 2009 | Acer Computers & Internet
Have gone to black!
The error: Window could not start because the following file is missing or corrupt;
WINDOWS\SYSEM32\config\system
You can attempt to repair this file by loading the Win CD into your cdrom drive. Start the PC & press the F5 key every 2 seconds & windows boot menue will load.
Choose the cdrom drive that has the Windows CD in.
Select "r" at the first screen to start repair.
Once back in windows run a full system virus scan.
Good luck & have a great day!
Mar 14, 2008 | Computers & Internet
Acer l100 cuts out for no reason
I suggest to remove the program for itunes, i think it did make a mistake  to the operating sistem
Dec 06, 2007 | Acer Aspire L100 PC Desktop
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
