Question about Bose Wave Radio
No sound. older model Bose. no static or any noise/music at all. Pushed mute on remote and it switched from AM to FM. Removed remote battery hoping to just control from radio...no success.
    Problem Solver:
  • 6 Answers
FIX YA IS NOT PAYING US THE MONEY WE EARNED (MOST OF US)! AND A SUIT IS BEING FILED WITH THE DISTRICT ATTORNEYS OFFICE! I SUGGEST YOU GO TO ANOTHER SITE TO GET YOUR ANSWERS!
Posted on Feb 15, 2009
I have Philips Flat Tv model # 42pf7320a/37 ..I have a clear picture but no audio, just white noise and static.
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 23, 2015 | Philips 42PF9630A 42 in. Plasma Television
Bose radio on but no sound
Make sure you haven't pushed the Mute button on the remote by mistake. Push it again or the Volume^ button to release mute. Also make sure the radio isn't on CD or AUX. Push the Radio button to return it to radio listening.
Jun 28, 2014 | Bose Wave Radio
I have a Bose Lifestyle v20 home theater system and whenever I use the radio ( FM/AM ), no sound/music comes out. The rest are fine, but only the FM/AM ones dont work. It used to, but now its gone.
I hope you checked if the antenna wire is connected before reporting this defect.
All modern radios have automatic muting. No sound will come out unless the receiver gets enough signal strength to give you an undistorted sound, so if your antenna wire is disconnected you will get no sound.
Jun 15, 2011 | Bose Lifestyle V20 System - black Theater...
I have an older onkyo integra (TX-870) which pop when I change stations, then no sound. Need to turn off and begin again. Can this be fixed or should I purchase a new 2 channel sys?
Hi, It sounds like you are listening F.M. radio and the F.M. muting button is engaged ( as well it should be-otherwise you will have static between the stations ) sometimes there is almost a "THUMP" sound when you switch stations-this is caused by the receivers P.L.L. circuitry losing then locking in on stations, if you do not lower the system volume you will amost assuredly cause an overload of your final drivers, that's why it will come back on when turned off-it has reset. Turning off fm muting will get rid of the "POPPING" noise-it will however leave you with unbearable static which in turn should cause you to lower volume momentarily eliminating the need to constantly turn off the receiver. Thank for asking FixYa, I hope this helps, let me know how I did or if I can be of more assistance, good luck Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
I have the Bose Companion 3 Series II speakers. I ordered them through the Bose website. However, I continuously hear static. Mute, low volume, with music, etc. I hear static noise. The only way to...
I have had totally the same problem before, and I have discovered that it is actually because of the electric current running through the speakers when the volume is low or muted.
I am afraid to tell you that the only solution to this problem is to raise the volume, as it is not a malfunction in the speakers but in the electric current running through them.
Good luck.
Dec 16, 2010 | Bose Companion 3 Series II Multimedia...
My bose wave not function in radio (not sound)
it never gives problem like this look out for aerial connection if it not connected properly then it goes in mute mode. try by changing bands(fm / am)
May 28, 2010 | Bose Wave Music System CD Shelf System
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
AM static
the easiest way would be to move the radio farther away from the furnace.
Sep 13, 2008 | Bose Wave Music System CD Shelf System
Lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Jun 14, 2006 | Bose Lifestyle 12 System
Bose Wave Radio Logo
145 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Sheila Brown
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
