Question about Panasonic DMR-E85H DVD Recorder
Panasonic DMR-85H remote non-responsive
We have two DMR-85H's set up in parallel at my work. At some stage someone changed the code on one of the remotes. We went from having 2 remotes that operated seperate DVD players, to having only one remote that works at any given time but operates both DVD players simultaneously. I was unaware of this and must have changed the code on the remote that was working, done something to change it, and now neither remote can access the "functions" page to change the codes back to their original settings...in other words both DVD players are saying DVD 1 and the remotes maybe DVD 2?
Does anyone know if there is any way to access these settings without using the remote and only the recorder itself or possibly reset the remotes manually? Any help on this would be much appreciated.
LDM
  • lormcp10 Feb 15, 2009
    Ok...cheers, any suggestions for which site i should try?
  • 3 Answers
Press and hold 1 and enter on the remote for 2-3 sec's the remote will be on 1. If you need 2 or 3 do the samething,
Goodluck
Posted on Feb 23, 2009
  • wrigs1 Feb 23, 2009
    Follow up, hold the 1,2 or 3 key on the remote and enter button at the same time to change the code. Once code is changed you can go to setup menu and change the remote code, but keep in mind once you do this do the above to the remote as well. If you have any questions please let me know. Remember to hold the number and enter key about 2-3 sec's.
    Problem Solver:
  • 6 Answers
FIX YA IS NOT PAYING US THE MONEY WE EARNED (MOST OF US)! AND A SUIT IS BEING FILED WITH THE DISTRICT ATTORNEYS OFFICE! I SUGGEST YOU GO TO ANOTHER SITE TO GET YOUR ANSWERS!
Posted on Feb 15, 2009
I have a panasonis DMR ez47v and a ez48v. the remote will work on the 48v but not on the 47 v are the codes the same Den
Panasonic remotes have a number of code sets. Thus if you have more than one panasonic device the remotes will not clash. Check the manuals for the code sets and how to change them.
Good luck
May 30, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
On a Panasonic DMR-EZ48V I get a U56 error message when selection drives? When I scroll down from DVD to SD then VHS. When on SD scrolling to down to choose VHS drive, U56 appears on DMR-EZ48V's screen? I...
I think it is usb, not sure why that happens though. Panasonic for some very weird reason mixes upper and lower case letters in some of their on screen bits, so you never know for sure.
I know nothing about this stuff but was having a similar problem with not being able to get the dvd recorder to record onto a dvd.
This was after I had set up the camcorder to the set the day before.
I finally went to 'input select' on the remote and changed it until it worked again, just go through each setting until everything is back to normal.
Somehow, it appears as if the dvd recorder got itself set to the camcorder and would not let go of that setting without changing the input select. I have no idea why because I never touched the input select before this, I always controlled everything with the Directv remote. Hope this helps someone.
Feb 23, 2011 | Panasonic DMR-EZ48VK DVD Recorder
Pansonic e 85h won't play recorded disc or finalize recorded discs also unable to play previously finalized discs, hdd is working and recording fine, what could be the problem on this dmr e 85h panasonic...
The symptoms sound like the laser needs cleaning adjusting or replacing by a qualified technician. If it is under warranty then you can return it. The only other thing youmight try is to open it and gently clean the laser lens with a q tip and a drop of alcohol if you know how. Otherwise get it professionally serviced.
Kind Regards
Chris
Mar 12, 2010 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Feb 15, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Remote will not control DVD/VHS
Tries change with new bateries,clean the The IR infered in the DVD/VHS combo unit,and the remote.
Aug 16, 2009 | Panasonic DMR-ES35VS
Hello, I have a Panasonic DMR-EH65 DVD with HDD, when pressing any button on the remote control the display says DVD3, machine will not operate, took it apart to check for any bad connections, reassembled...
You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Mar 15, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
Jan 17, 2009 | Panasonic DMR-HS2 DVD Recorder
DMR-EH50 DVD Recorder
Check your user guide for the answer.
Nov 08, 2008 | Panasonic DMR-EH50 DVD Recorder
Remote controle
Easy to fix. The DMR E55 has 3 remote control code settings and your remote can be set for any one of them. The error you are getting at the moment means that your remote is set for one code but your DMR E55 is set for another. Why do Panasonic do this? The reason that Panasonic do this, is because if you have several Panasonic units, you can operate one of them from your remote without all of them responding at the same time. Ok, so how is it fixed? Turn on your DMR E55 and press FUNCTIONS then select SETUP. Then select OTHERS. You will see the remote option on the right which will say DVD 1 or DVD 2 or DVD 3, Try setting it to a different code and press return. You should get it to work...
Sep 19, 2008 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
338 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
