Question about Gateway MX6454 Notebook PC
Volume "Volume cannot be changed.Full Volume even if reduced or muted"
The volume when changing input, source or equalisation is very high. Is there any way to reduce it.
What type of system is this on? Can you please provide more information? Brand/model is always good. Thanks!
Jun 15, 2016 | Computers & Internet
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
Www urcsupport com
Does your TV have a "half-mute" setting:
* press MUTE once to reduce the volume to 50%
* press MUTE a second time to reduce the volume to zero
* press MUTE a third time to restore the volume to 100%
Jul 01, 2013 | Televison & Video
How can I mute my phone?
You mute your motorola phone by reducing the volume to the last.When you reduce the volume it will get to vibrate when you press further it will give you the mute.
Jan 24, 2011 | Motorola Mobility W385 Cellular Phone
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Volume problem
try reducing the output volume from the pc, maybe to about half or even a quarter of full volume. now increase the volume on speakers.
Mar 21, 2010 | Logitech X-540 Computer Speakers
My microphone wont work
It is the settings that matter. Go to the Volume icon in the system tray in right bottom corner and you will find MIC in the box that opens. Please unmute the mic and also reduce the volume for the mic. It is high volume here that is producing the screech and muted mic that does not send your speech. So do the needful here. Somehow Windows is in a habit of muting the mic on its own. Keep checking it once in a while.
Dec 13, 2009 | Logitech Webcam
Garmin nuvi won't talk
Go to Tools|Settings|Language|and change it to "American English (Jack or Jill) TTS).
Jun 13, 2009 | Garmin Nuvi 660 GPS Receiver
You need to first find out what chipset your on-board card uses my friend. Check all the documentation to find out. You will need the exact set. Now search the net for an updated set of drivers that matches your operating system (XP SP1/2 etc). Now go to device manager and delete anything which has sound connections (MIDI Interfaces, MICs etc..). Now click the 'scan for changes' icon in device manager. Use the new drivers you downloaded.
Jan 25, 2009 | HP Pavilion dv6000z Notebook
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Jan 01, 2007 | Denon AVR-2802
Gateway MX6454 Notebook PC Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
