Question about Sony Playstation 3 (PS3) Console
Nothing comes up on Home Screen?
I haven't used my PS3 for a couple of weeks, and when i decided tp use it again, it went to the home screen fine, then it all froze and i couldn't select any options.
I turned the console off and on again, this time it loaded to the home screen but only the background loaded, none of the icons came up at all.
I restarted again and the same thing happened, none of the icons came up. It also won't play any disks that i put in the drive.
I'm really worried now, before this it was working perfectly fine.
Does anyone have any ideas of what has happened?
    President:
  • 2,653 Answers
If you can get to it without it freezing use the System Restore function under:
System->Settings>Restore PS3
If you can't get to it because of freezing you should put your hard drive into another PS3. It will see it as a new drive and prompt you to format it. Afterwards put it back into your PS3 and it will do the same thing again.
It doesn't matter which PS3 yours or the one you put your hard drive into, they're all the same as far as the process goes.
Posted on Feb 21, 2009
Red screen on ps3 and i can do nothing anymore
Hi darkstaf,
This is similar to the red light problem but the reason you get a screen is because the GPU has overheated.
You just need to stop the heat build up getting to the main chips and you will be able to play your games again.
To do this you have 2 choices:
Send it in and they will fix it for you although something to bear in mind that it will take 4 weeks and cost you $150 for the fix.
Or you can use a good PS3 Repair guide and fix it yourself.
A word of warning before attempting any home repair solution:
CLICK HERE TO CHECK OUT A FULL REVIEW OF ALL THE PS3 REPAIR GUIDES FIRST
I hope this helps.
Mar 16, 2011 | Sony Playstation 3 (40 GB) Console
PS3 problems At home I have a new samsung hd 1080p TV that I normally use for my PS3. I will be in a hotel outa town for the next couple of days and I wanna watch a movie using my PS3. In my...
I had the same problem, stuck in a hotel room for 2 days. When I held down the button, next time I turned it on, I got the same prompt with using HDMI output, said yes, and screen went black. However, a screen then came up asking if I could see the image or not, but it has a 30 second time limit before it saves those setting, you have to click "No" on this screen, and it will drop the resolution to 780p instead of 1080 and it should work! Make sure you're paying attention so you don't miss the screen!
Nov 13, 2010 | Sony Playstation 3 (PS3) Console
I have two seperate playstation 3 consoles. One works just fine, but did not include the audio/video cables. The other one will not read blue ray disks. The cables from the one that cannot read disks will...
Ok, for the one that does not show the home screen, try this :
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again about 5 seconds later. Release the power button when you hear the second beep.
Step 3. The PS3 should now come back to life on the screen.
What this has done is basically reset the PS3 display back to standard definition.
If this does not work please reply here and I will try another solution with you.
Thank you for using FixYa
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
Blan White screen
try holding the power and the square at the same time till it shuts downand the apple logo shows up then release
May 12, 2010 | Apple iPhone Smartphone
Can hear sound and see picture but it is all fuzzy
u need to reset the screen options back to regular spec if its not a 1080 p tv if its a regular tv you will need to use the 1080 p tv to fix it before you can use it on any tv
May 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
My 8gb creative zen player: it was working fine yesterday, cycled home in the rain and i think it got a bit wet, i switched it off, then it switched itself back on with just a grey screen, it now won't...
Mine got wet about a week ago - see my original response.. The screen was just flickering and I could see condensation on the screen. I kept hoping it would dry out, but days went by with no change. Yesterday I finally put it on the dash of my car and let it sit in the sun all day. When I came out of work that evening, the Zen seemed completely dead - and HOT! I let it cool down and plugged it into the charger - still nothing. But this morning -YAY! It is completely functional again!
Jun 27, 2008 | Audio Players & Recorders
GPS screen went blank
My problem exactly. Unit would start up, acquire satellites, then the screen would go blank with a single vertical line. Unit would not respond to buttons or even turn off. Unit works fine after I did the reset:
- w/unit OFF, press and hold QUIT+DOWN+MENU
- press and release the power button, release DOWN, keep holding QUIT+MENU for 5 seconds.
- unit prompts something like: "erase all data;" choose yes.
- you will lose waypoints, etc.
Go to the Garmin support area for details.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Search for: "How do I reset my gpsmap 76"
Oct 06, 2007 | Garmin GPSMAP 76 GPS Receiver
Sony Playstation 3 (PS3) Console Logo
198 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
