Question about Lasko Ceramic Heater
Lasko heater shut down
It just shut down no red light indicator that it is receiving power from any plug i hook it up to? Is it dead?
  • 10 Answers
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Posted on Oct 16, 2009
  • Steve Spahr
    Steve Spahr Dec 08, 2013
    Easy solution to keep your heater working!
    Problem Solver:
  • 8 Answers
It needs some cleaning .. you need to open the unit and vacuum all the collected dust in front of the heating element and back ...and all the visible dust ,,,
Posted on Feb 23, 2009
  • Steve Spahr
    Another easy solution to keep your heater working!
    New Friend:
Cleaning did not work for me, but this is the best option if it works. Definitely try that first. I cleaned the mesh filter at bottom of front of heater, blew air through element as recommended above, still shut down regularly except when used in very cold room, then it stayed on. I thought it might be an air flow problem, as restrictive flow could cause heat to build up. I cut a square hole, approx 3" by 3" in middle back of unit, no shut downs since. I suppose you could tape a filter over hole if you like, I left it open. I think the mesh filter at bottom front doesn't allow enough air in, could cause a higher running temp.
Posted on Dec 14, 2013
LASKO 5624 will not turn on. The red light underneath the clock button is on. How do I reset? Is this broke after 20 uses?
Disconnect power, (unplug); wait for over 20 minutes, (have a cup of coffee); Depress power button before pluggging in to wall socket . (This will let any voltages that are stored in the unit drain off).
Plug in to AC outlet and press power to turn on.
If this doesn't work, Lasko has a 3 year warantee.
CUSTOMER SERVICE:
Toll-Free (800) 233-0268. Email: producthelp@laskoproducts.com
Feb 02, 2015 | Lasko 5624 1500 Watt Convection Heater w/...
Unit powers up, then off 3 times before completely shutting down. At that time, the unit has to be unplugged from wall to try another time,
I have the same problem with my unit. It started today so I went and unplugged all wires(inputs and outputs) going to the unit. I plugged the receiver in and still the same results. Was there an answer to this question.
Apr 30, 2014 | Yamaha Rx-v565 Receiver
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Manual for ilive bluetooth receiver and adapter lAB13
Have you actually checked the charger is actually working with power coming out of plug that plugs into device.. THe actual charger unit may not be connecting properly into wall socket...
Dec 09, 2013 | GPS
Dennon gets hot shuts off
how are your four outside speakers hooked up? If you have four speakers hooked up to only two output channels on the receiver, the receiver is sensing a short and shutting down to avoid damage to the amp.
Jul 20, 2013 | Denon AVR-3806 Receiver
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
When i plug the reciver in with nothing hooked up no cables no speakers nothing i push the power button and it will flash a few times then it will go back to a solid red light i cant get it to do anything...
I have the same throuble about this >Pioneer VSX-D812 and in Manual exist the next section:
Chapter 10:
Additional information
Troubleshooting
If the STANDBY indicator blinks and the power shuts off
automatically, take the unit to your nearest Pioneer authorized
service center or your dealer for servicing.
Feb 20, 2011 | Pioneer VSX-D812 Receiver
X 346 powers on, then shuts down - no HDD installed
Even without the harddrive, you should be able to see the server power up with Bios/Memory test. It should be able to indicate to you that no drive found. In addition, you should be able to press F1 or F2 to enter into system setup.....hope this help
Jun 06, 2010 | IBM xSeries 346 Server
Lasko  Ceramic Heater Logo
1,806 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
