Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Lost a .dll file
Every time I start my machine, as soon as I log in a message comes up saying I lost khfCuTND.dll but the thing seems to run fine, I would just at least like to stop seeing that stupid message. I'm not sure how I lost it but I just need my .dll file back!
  • Hunter Williams
    Hunter Williams Feb 15, 2009
    Thanks, and actually I have always used Spybot. Now, any ideas on getting that message to stop showing?
  • Microsoft Master
  • 19,396 Answers
A file with that name is not lested on any website as part of known software.
That is probably a virus that had been found and deleted by your regular antivirus.
You can try to find out by installing and running a scan with spybot, the download link is below:
The home of Spybot-S&D!
Posted on Feb 15, 2009
  • Ginko
    Ginko Feb 16, 2009
    If you are skilled enough you can use hijack this to stop the process. Hijack this is a software tool that edits your system registry and if you use it in the wrong way you can damage Windows.
    |MG| HijackThis 1.99.1
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
I am running Windows XP Pro on a used home desktop I purchased about a year ago.It is a Dell computer/Pentium 4 CPU 2.80 G Hz/2.79 G Hz/512 Mb RAM. This computer is used by two other people in my home.My...
Try going to dll-files.com and download the necessary file. Copy that file to C:\Windows\System. Hopefully this works for you. If not, you could also reinstall Windows which will reinstall the necessary files.
Feb 24, 2011 | Microsoft Windows XP Professional
I lost my install disc. How do I install my
You can find the drivers at Brother.com, they are free to download.
Jan 28, 2010 | Brother HL 1440 Laser Printer
Following repair by an anti-virus file UACxitmtbjtwv.dll seems to have been damaged or removed, can you help? I need to replace / repair this file but don't have original discs, can I download? Regards,
I can't find any mention of this dll file anywhere. I believe that what you have is a remnant of a virus. I think it was a program that was set to run when Windows started up that probably kept reinfecting your computer with the virus and now that you have repaired the virus, this program is still trying to start but is missing that file. I would recommend running "msconfig" and going into the startup configuration and seeing if you can find any unfamiliar programs that are loading on startup. It will probably be a trial and error type of troubleshooting where you disable and enable them one at a time and try to find which program is causing that error message for that file when it loads. It could also be under "Start" "All Programs" >"Startup".
Jan 09, 2010 | Microsoft Windows Vista Home Basic Edition...
Error loading C:\PROGA~\MYWEBS~1\bar\M3PLUGIN.DLL
download avast home version its free and that will fix the problem
May 11, 2009 | Microsoft Windows XP Professional
MLANG DLL. IS MISSING
This happened with MS Windows some times if you don't want to say..it's often :)
Okay, this what you should do:
Download the missing file from here: http://www.dlldump.com/cgi-bin/testwrap/downloadcounts.cgi?rt=count&path=dllfiles/M/MLANG.DLL
Then, follow the instruction below:
How to install/uninstall MLANG.DLL? 1. Unarchive the package and use the files from Release folder if you're running windows 9x/Me or Release Unicode if you are running windows 2000/XP
2. Copy DLL files in system32 folder [C:\WINDOWS\system32]
3. Click on Start > Run
  • To install the dll files, type: regsvr32 MLANG.DLL
  • To uninstall the dll files, type: regsvr32 -u MLANG.DLL
  • run.gif 4. In the end, you should receive a message saying that your file was successfully installed/uninstalled
    P.S.: If this information was helpful, please rate this solution.
    Mar 23, 2009 | Microsoft Windows 98 for PC
    Runtime errors
    Solution:
    i) usually whenever there is virus, spyware, ... in your system some of the .dll will be lost or will lead to curruption or partial currption(some data or all the data in the .dll will be lost)
    ii) as such some .dll files are heart or important to run system, some .dll files play mere role.
    iii) when such .dll files are lost the program using these .dll files cannot locate or find their .dll files in such you get errors message as u said......
    iv) as u debuging is not possible in the normal way until unless you have some debugging program or software such as "Visual Studio 2005" or Visual BASIC TOOLS....
    v) due to loss of some important .dll files your system might shutdown frequently..... but you are fortunate that you are getting error message....and these .dll play mere role....
    vi) i would suggest to install some best rated antivirus, spyware( Bit Defender -rated top, AVG, Norton....) after perform full system scan try reinstall your OS or format your system or load OS Freshly....
    Thanking you
    M. Sridhar
    Dec 27, 2008 | Computers & Internet
    Lost my installation CD and downloaded the software from HP but doesn't work
    To register .dll files follow these steps: 1. Click Start, click Run, type cmd in the Open box, and then OK. 2. At the command prompt, type the following commands, and press ENTER after each command:
    regsvr32 /u sccbase.dll
    regsvr32 /u slbcsp.dll
    exitNote Click OK if you are prompted.
    3. Restart your computer. 4. Click Start, click Run, type cmd in the Open box, and then click OK. 5. At the command prompt, type the following commands, and press ENTER after each command:
    regsvr32 sccbase.dll
    regsvr32 slbcsp.dll
    6. Restart the computer.
    Mar 10, 2008 | HP DeskJet 3940 InkJet Photo Printer
    Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Brian Sullivan
    Brian Sullivan
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
