Question about Toshiba Televison & Video
Vertical Colour bar on Toshiba 17WLT56B LCD TV
HiI have a Toshiba Digital LCD TV Model 17WLT56B. It worked fine until 3 days ago when it started to display a vertical green stripe about 2 inches wide from top to bottom of the screen. It is about 2 inches in from the left hand side.I can see the picture through this colour band.Any ideas please
Tony
  • 153 Answers
Hi the fault is in picture tube
Posted on Feb 16, 2009
  • nicra7 Feb 16, 2009
    the picture tubes rgb configuration might be fault
Toshiba 19DV500B screen has a white hue on tv picture, how do I resolve?
If the tv menu is also messed up then the lcd panel needs replaced. if not under warranty replace the tv.
May 08, 2014 | Televison & Video
I Bought Toshiba LCD TV Model 32A3000E 3 years ago, now when we switch on for approx 2hours the LCD screen distorted with green and red colour and getting worse. The next day it is ok again and here goes...
If the tv tend to operate when it gets warm this cause a thermal intermittent problem, common cause is the cold solder or loosed connection try to check the main pcb or the power supply solder side of the board then try to observe if there is cold solder or slight cracked to the lead try to solder that part. Note before opening or removing the back cover of your tv, be sure to unplug it first to avoid serious injury. Or try contact a service repairman to do it for you to lessen the stress. good day hope this may help.
Jul 13, 2011 | Toshiba Televison & Video
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
Vertical colour bars
The problem is in the LCD controller board is overheated because the power supply unit is at the bottomof the TV and the heat rises upward to the vent on the top of the TV. You can verify that is hest problrm by running TV with the back removed and have a small fan blowing on the top secdtion of the TV where the LCD controller is. This how I fixed my scrambled picture after warm up (I added heat sinks to the IC on the LCD controller board) : http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You can try it if the board was not badly damaged already by the heat. My has been running great for over a month now.
Feb 04, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Toshiba rear projection TV 43VH9UA
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
May 12, 2009 | Toshiba 43H72 43" Rear Projection...
Toshiba md12m1 tv/dvd, original remote needs reprogramming
i have a toshiba tv how do i reprogram it ,evry time the electric goes out the tv goes out to be reprogram and i for got how and do not have i book.
May 04, 2009 | Toshiba Televison & Video
The picture on my toshiba 17WLT56B goes off
hi sir,,
there are only three things to check which causes these problems...
first check whether the cathode ray tube is ok or not
second whether the fuse is damaged
third is the colour wheel,,,
if these are not defnility the circuit problem,,,diodes capacitors
thank u,,,,,
Mar 06, 2009 | Televison & Video
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Mar 04, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
181 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
