Asrock PIV mother board with Intel CPU.When I switch on,CPU fan start.Suddenly stop.I check power supply by shorting 14 and 15 pins together.Then power supply switch on:then I check voltages orange 3.3.Power good line also ok.Then I decide power supply is good.Likewise problem may be in motherboard,CPU or ram.(On board VGA)IDE and all PCI cards removed.
Then I remove ram and switch on.CPU fan started then suddenly stopped.
I forgot tell you.If I switch on PC then fan started and stop nor,Again I couldn't switch on.If I press switch on button no result.Then I disconnect power supply cord from PC.Again reconnect and switch on then same result.CPU fan started again stopped.
So what do you think?Can you support me to get correct solution for this.I need to finalize problem in rams,mother board or CPU.
Bye Narada Dilshan
Comments:
Feb 15, 2009
- Thank you for your Answer.I test them.No any bulging out or leaking. It mean I can repair it.Because those capacitors can remove easily.If I replace with new one mother board should work isn't?
According to my knowledge this should be problem in capacitors.Isn't. Because I have to discharge it by unplugging.What do you think
-   I have the same problem and have tried second,third power supply only to have same results. My guru says most likely time for new motherboard.
-   Guest
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Comments:
Feb 17, 2009
- well sounds like you probably have a bad power supply, you can test this by easily by either borrowing one with the same plugs from another pc, most are the same now adays or buying one and testing with it. since you say your caps are not bulged i would put my money on the power supply
i want to be audio drivers for pi945gzd motherboard please tell me how can i download this drivers...
(More)
i want to be audio drivers for pi945gzd motherboard please tell me how can i download this drivers sir
dont know the correct jumper settings for my e machin.es t6534 monitor doesnt read as on. please...
(More)
dont know the correct jumper settings for my e machin.es t6534 monitor doesnt read as on. please help
jumper was blown off during maintence,i put it back to where i thought it was only to discover i...
(More)
jumper was blown off during maintence,i put it back to where i thought it was only to discover i NOW need a password.
