Power Light on but screen black
Last night i pressed a few buttons on the lap top key pad, the buttons were around the space bar. The laptop froze and nothing would work, not ever CTRL ALT Delete. So i held down the power button to turn it off. I then restarted the laptop. The power light came on but the screen stayed black.
I have tried running the battery down then recharging it but this did not work. Any ideas any one. I would reaaaaly appreciate your help.
Thank you.
PS im no good at computers so please explain as best you can xxx The power light is on but the screen remains black. At times, the power light remains on while the screen remains black while at other times, the power light goes off after awhile. However, normally after a few days, the laptop returns to normal working condition. But now, about a week has passed, and the screen remains black whenever the i on the laptop.
  • RRahul Mar 12, 2009
    I have the same problem in my compaq prasario v3000
    Sergeant:
  • 395 Answers
Try powering up with no battery connected. If that works then the battery may be faulty or too old.
Posted on Feb 15, 2009
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
Startup logo appears then it goes to a black screen and blinks
You should try booting into safe mode. Press the F8 key before the windows logo and choose safe mode without network support. If windows loads run a checkdisk by right clicking on the c drive, left click on properties and then select the tools tab. From there you can run a disk test to check for errors. If you get that far then reboot and see if it starts normally. If not try F8 again and try selecting restore the last known working condition. This will restore your settings from the last time it worked. If you can’t get to the F8 screen get back with me and I will try a few more drastic solutions. Good Luck
Jul 22, 2009 | Computers & Internet
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Lap top screen is black
If you are running with XP try switching the unit on and pressing F8 while the computer is booting up
This should put you into Safe Mode
If that works go to Start , Accessories, System Tools ,System Restore and if the shop did the right thing when they built it you will have the System Restore function running
Ask the machine to do a System Restore and it should give you a number of dates to restore to, pick on that is a few days before the last update and let it roll
Jun 02, 2009 | Acer Aspire One PC Notebook
Welcome to Fixya !
IBM laptops generally comes with protection mechanism to stop the harddrive if the laptop experieces heavy vibrations or shocks. This is to avoid any possible impact to the hard disk and its data. But this sometimes freezes the Laptop. The screen may be blank because you might have pressed a combination of Fn and F3 which will switch off the screen. Try to press the same combination to bring the screen back up.
Jan 12, 2009 | IBM ThinkPad T23 Notebook
Last night i pressed something on my laptop and it froze. I couldnt even press CTRL ALT Delete. So i held the power button down to turn it off, then when i tried to turn it back on again, the light came on...
Hello!
Great description of your problem, can you elaborate? what was pressed to freeze the program?
Have you the bootable disc for your operating system i.e. Windows? if Vista? power up the Lap Top pop the system cd in the drive then shut down.
Cold boot and you should be ask if you want to boot from cd? press any key (Do this) you should then see Windows loading files then you will be asked Location? U.k. England London etc., select your area.
Key board layout next, i.e. English or U.S. layout? find the area you require by drop down list. Remember choosing U.S. if in U.K. will change Layout Of £ & $ after selection the next page will ask for either full install? Upgrade? or repair? click on repair and hopefully you are Fixya'd & back to normal.
Please remeber me if you are sorted by leaving your response.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><U.K.
Computers & Internet Logo
703 people viewed this question
David Payne
David Payne
